test problem
KevO · 17030
Offline KevO
Reply #30 on: April 24, 2013, 08:40:24 AM
Gentlemen,
Just tested without the crossover. 1 pop instead of 3-5. So it appears the active crossover is more sensitive.
I put the o-scope on Beepre out and watched. But I have no idea what any of it means. Time to learn more about using the oscilloscope.
I found a diagram of the c-r filter (high pass) here; http://www.learnabout-electronics.org/ac_theory/filters81.php
Not sure how to build it into the crossover since it is a circuit board, but can I put the parts on a M/F RCA jack and insert it to the end of the BeePre out cable? How much will it cut the bass? The bass sounds great right now.
-Kevin
