foreplay with sweetest whisper
najo49 · 3833
Offline najo49
on: April 11, 2013, 08:36:23 PM
I installed the sweetest whisper on my foreplay 2. I used the 33k resistor on it but the gain is quite about lower. Is there another risistor value lower than 33k that I can use? Jan Olsn
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Reply #1 on: April 11, 2013, 09:04:49 PM
If you wire the switch, with no extra resistor, as a potentiometer then you will get about 10dB more gain, the same as any other (e.g. the original) potentiometer. It will then have a 15K input impedance, which is low for some gear but fine for most.
Reply #2 on: April 12, 2013, 08:08:18 AM
Paul is saying that it won't matter for most sources but you might have the source that is the exception.  If you can find the output voltage and current limit of the output we might be able to answer the question without any maybes.
