Crackling noise right channel and LED blinking on Crack/Speedball
TontonFlingeur · 3833
Offline TontonFlingeur
Hello,
I recently upgraded to Speedball and after several days of troubleshooting and lots of help from the forum got everything working.
But now I'm getting a crackling sound in the right channel. I flipped the plate over and noticed that the topmost/rightmost LED on the center PC board blinks at the same time as the crackling noise crackles. The noise is intermittent and varies in volume.
I have poked around solder points and wires with a chop stick but haven't been able to get the amp to crackle more.
I've also reset the tubes. I don't have spare tubes, and wanted to check with the forum before ordering new ones.
Any thoughts much appreciated!
Dave
Yeah, you are correct to be suspicious of solder joints, I would gently turn the board sideways and touch up all the PCB joints.
The key being  "gently" - those joints are fragile.
It's all working now and sounding great, but time will tell.
- Dave
Offline Laudanum
You're probably ok now.  Sounds like just a cold solder joint causing the intermittent connection.  Relax and enjoy !
Desmond G.
I think the worst is behind me. Got through Friday Night in San Francisco and Dark Side of the Moon without any problems. I can start spending too much on tubes now!
