Need help trouble shooting Foreplay Extended III upgrade
docbob52 · 2598
Offline docbob52
After installing the upgrade, I note that LEDs on  the c4s board on the A socket do not light up when plugged in.  The LED's on the the B side and the Shunt regulator board all light up correctly. Without removing the A side C4s board I have checked all point to point wiring and the pc board and all appear to be correct.
What should be my next step?
All help appreciated.
Robert Howard,
Troy, Al.
Garrard 301/ high mass plinth, SME 312S tonearm/ Sleeping beauty cartridge/ Denon AU 320SUT. Transcendent audio GG preamp and OTL SOB power amp. Blumenstein Orca/Dungeness Speakers
Second system.  BH Paramount 300B amps.  BeePre.  Sony SCD777ES, Wyred4 sound Dac. Mac mini.
Offline docbob52
Reply #1 on: April 26, 2013, 07:52:09 AM
BTW, I got abnormal readings on Terminals:
Terminal 12:    I got 0 volts and should have been 150v
Terminal 15:  I got 1v and should have been 75v
Terminal 31:  I got 146v and should have been 75v.
Reply #2 on: April 26, 2013, 07:54:41 AM
Make sure that the proper transistors are in the proper positions. There are some labeled 2N2907A and some labeled 2N2222A. They look the same, but are different. Also double check the orientation of the silver end of the LEDs. Also make sure the correct resistors are in the correct positions.
Offline docbob52
Reply #3 on: April 27, 2013, 04:30:18 AM
Thanks Dan,  I found some reversed diodes and transistors.  Dyslexia strikes again!
