Isolation transformers
tsingle999 · 2278
Offline tsingle999
on: April 29, 2013, 03:28:08 PM
I have a powervar 3.0. After i blew out an expensive tube and an amp i pulled this out.
I put in an 1kv tripp lite isolation transformer. I like the sound better with it in my building.
Anyway i got around to measuring the ac voltage: the powervar was 125.5 at all 4 taps. 122.5 for the tripplite and 120 from the wall. What is going on here? Is that why i blew the amps?
Bottlehead Stat headphone amp
Reply #1 on: April 29, 2013, 04:50:57 PM
Isolation transformers produce the rated voltage at the rated current. In order to do so, they must have a voltage step-up function, so at less than the rated load the output voltage will be greater than the input.
Most tube equipment will tolerate +/-5% with little problem, and +/-10% before serious damage occurs rapidly. But of course much vintage gear was designed for 115 or 117 volts input - and most modern gear uses power transformers designed many decades ago, and rated for 115 or 117v input. Those power transformers also put out more voltage than specified unless they are loaded with the specified, usually maximum, load. Given the enthusiasm among many builders for over-rated components, excess voltage is not all that uncommon even if the input voltage is 120v (the current North American standard).
Hard to guess what exactly caused your particular problem - over-voltage is a possibility, but it may or may not be a probability.
Offline tsingle999
Reply #2 on: April 29, 2013, 04:56:50 PM
Ok thanks for the explanation:)
4krow
Reply #3 on: April 29, 2013, 05:24:42 PM
To make things worse, you can't always trust the voltage from the power company, especially if you live in a rural area.
