what if I wanted to add a third input to my Quickie...
denti alligator · 14979
Reply #15 on: June 14, 2014, 09:30:23 AM
Do you now get the same voltages when you now switch to the 3rd channel with your power switch on?
Offline WK3K
  • Beginning to see the light...
Reply #16 on: June 17, 2014, 12:36:36 PM
I get the same voltage readings regardless of which channel (1-3) I set the rotary to. They all seem to be within normal limits for the PJCCS quickie.
W
Witold
Rega P3-24 w/ Rega Exact > Eros II> Quickie w/PJCCS > Stereomour II w/ DC filament supply > Blumenstein Orca Mini/Max 2.1
MacBook > Grace SDAC > Crack w/ Speedball > Sennheiser HD6XX
Reply #17 on: June 17, 2014, 05:48:42 PM
I would test the DAC independently from the Quickie.
Offline WK3K
Reply #18 on: June 18, 2014, 04:51:53 AM
Thanks Paul! I was going to update this last night, but it looks like the site was down. I have been poking around at the DAC and have gotten it to play (sporadically). Anyhow, I'm satisfied that the problem is with the DAC and not with the quickie and that this approach for adding an extra channel is sound. I appreciate the help!
Witold
Witold
Offline denti alligator
Reply #19 on: July 28, 2015, 06:25:18 AM
http://www.mouser.com/ProductDetail/NKK-Switches/M2044SS1W01-BE-RO/?qs=sGAEpiMZZMvudeGI7i40XP93sFwtDpTaZ1OHH5C0U5Y%3d
This one would probably work.  It can be somewhat difficult at times to tell if a toggle switch has a momentary position on it or not.
You'll have to analyze the datasheet and pay careful attention to the "external connection" reference therein.
OK, I'm finally gonna try this. The part linked to here is no longer available. Can someone point me to a switch that would fit where the existing switch is already mounted in the Quickie. My plan is to add RCA jacks between the input and output jacks.
Also, the switch linked to here is a DP3T switch. Is that what I need? or is it a 2P3T switch?
« Last Edit: July 28, 2015, 06:27:04 AM by denti alligator »
- Sam
Reply #20 on: July 28, 2015, 08:28:44 AM
DP3T is Double Pole Tripple Throw.  Those are one and the same.
Reply #21 on: July 28, 2015, 11:32:03 AM
OK, so if I get one of those, plus two extra RCAs, then I should be good to go? Just wiring to stress over?
I see there are six terminals to wire, which I assume means two of these will take the inputs *and* one of the sets of three outputs.
- Sam
Offline Adrian
Reply #22 on: July 28, 2015, 01:45:50 PM
I added 3 switched outputs to my submissive.
This might help with your decision:
http://bottlehead.com/smf/index.php?topic=7864.msg75569#msg75569
Adrian C.
Reply #23 on: July 28, 2015, 02:38:10 PM
Well, I really don't know what I'm doing here, but I think this should work:
http://www.mouser.com/ProductDetail/NKK-Switches/M2044SS1W01/?qs=sGAEpiMZZMsqIr59i2oRcjnUQmNlpKWknidTKccPOa4%3d
The wiring is another issue. Anyone be so kind as to link to the RCA jacks I should get at Mouser?
« Last Edit: July 28, 2015, 02:40:17 PM by denti alligator »
- Sam
4krow
Reply #24 on: July 28, 2015, 05:18:26 PM
 I don't do much business with Mouser, but I have found some RCA jacks that are quite a deal at Ebay. They are offered by Manley Labs for $5 each. I have been using them for awhile now with no regrets.
Reply #25 on: July 29, 2015, 10:36:18 AM
Well, I want to just make one order, and hopefully save on shipping, too.
These look right. Unless someone says "wait! those won't work!" I'm gonna order these:
http://www.mouser.com/ProductDetail/REAN-Neutrik/NYS367-2/?qs=sGAEpiMZZMv0W4pxf2HiV971L5dkS74PmXnOE1s2ZlQ%3d
http://www.mouser.com/Search/ProductDetail.aspx?R=NYS367-0virtualkey56810000virtualkey568-NYS367-0
- Sam
Reply #26 on: July 29, 2015, 12:29:02 PM
Ok, ordered these. If anyone wants to have a look at the data sheet for the switch
http://www.mouser.com/ds/2/295/MtogglesBushing-31423.pdf
and give me some advice on wiring, I would be grateful. My head is already reeling trying to make heads and tails of it.
- Sam
Reply #27 on: August 03, 2015, 07:32:20 AM
OK, got my switch (M2044 is the model). I would be very grateful for any pointers on wiring! I really don't know what I'm doing here.
Picture should help.
My guess:
line out = 2(red)/8(black)
RCA(1) in = 6(red)/12(black)
RCA(2) in = 4(red)/10(black)
RCA(3) in = 1(red)/7(black)
I take it "external connection" means I need to solder in a jumper wire?
« Last Edit: August 03, 2015, 10:56:26 AM by denti alligator »
- Sam
Reply #28 on: August 03, 2015, 12:28:02 PM
How many pins on your switch?
Reply #29 on: August 03, 2015, 12:54:31 PM
It's the one circled in the picture. 12.
- Sam
