Measurements for the Stereomour base
mpeg2 · 3638
Offline mpeg2
on: May 18, 2013, 09:55:59 AM
After building and then thoroughly enjoying a Crack headphone amp - I took the plunge today and ordered a Stereomour kit. I'm planning on building a different base for it, using a different kind of wood.
I know the top plate is 10"x12" (and also know to wait for it to arrive before doing the final bits on the base) - but don't know the other dimensions of the supplied base - wood thickness & width of the boards - can someone who has one do a quick measure & post?
This will help me find a nice piece of wood while waiting for the kit to arrive.
   Rich
Offline Follow the white rabbit
Reply #1 on: May 19, 2013, 01:29:09 AM
More important is the question if you want to lime in some wooden strips for securing the base or do you know a carpenter who can mill out wood on the inside for securing the base like Bottlehead offers...?
I went the first option way...
Do you want angels or just blunt connections...
Offline mpeg2
Reply #2 on: May 19, 2013, 03:13:16 AM
Haven't quite decided the approach yet. "Milling" the rabbet that the top plate sits in is not all that hard (using a router is one way) - but strips work too and might be easier. I don't have a table saw anymore - so butt joints are probably the way I'll go.
To be honest, the base for the amp is pretty routine - I've been doing head cases for guitar amps for a while now and this is a little simpler. The fun part (of the woodworking) is to find the right piece of wood.
This picture shows my earliest attempts for head cases.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fpsip.home.comcast.net%2F%7Epsip%2FGilmoreP1Ex.jpg&hash=357eeef3a2ab340f5d3430e463251f252b0f5fce)
   Rich
Reply #3 on: May 19, 2013, 07:35:33 AM
The 10" length of wood that came with the Crack is the same as the 10" piece supplied for the front/back edges of the Stereomour.
(If you didn't order a Crack base, let me know and I can go measure a piece, I think they are around 3-1/2-4")
Offline mpeg2
Reply #4 on: May 19, 2013, 07:48:06 AM
Paul: I'd really appreciate it if you could measure - my Crack is in my office & I won't be going there for another week (travel)...
Thanks.
   Rich
Reply #5 on: May 19, 2013, 08:16:13 AM
They are 3-1/2", then roughly another 1/4" for the rubber feet.
IIRC, the BeePre and Eros are the two kits that really need the full depth.
Offline mpeg2
Reply #6 on: May 19, 2013, 08:47:24 AM
Paul: Thanks very much...
   Rich
