Should I replace this cap? [solved]
Neuronal · 6191
Offline Neuronal
    • Datta Lab Website
on: May 18, 2013, 05:59:50 PM
I was replacing the Shottky diodes on my SEX amp (which, I kid you not, blew out while playing R. Kelly in my lab at like volume 9) and since I am a total repair newbie I think I accidentally touched the side of the 1 uF/630 V cap as shown below and melted the outside some. What to do? I could ignore it, cover with electrical tape or call the Queen to replace the cap (and potentially melt some other part during that replacement install :) ) Any advice is truly appreciated!
best to all - Bob D.
« Last Edit: July 11, 2013, 05:14:54 PM by Caucasian Blackplate »
Bob D
Rega P2, Cosecant DAC, Reduction, EFP III, Paramount V1.0 + soft start, Omega CAMs + DeepHemp 8s
Reply #1 on: May 18, 2013, 08:53:53 PM
Replace the cap. There is a significant possibility that it is now internally shorted, or that it will soon be shorted.
Offline Neuronal
    • Datta Lab Website
Reply #2 on: May 19, 2013, 02:14:27 AM
Thanks Paul!
 I was planning in the future to upgrade to new iron with the C4S board and new caps. I already have bought the cap upgrades - for the coupling cap (which is the one I think I melted) the ones I have in hand are Auricap .2uF/600V. Four easy questions: Can I just replace the coupling caps now without making any other changes? Does orientation matter? Because of the size of these new caps, I am also worried about space - can I leave the leads long and tape the caps into place? Will doing this now get in the way of the iron/C4S upgrade?
Thanks again for the help - I would love it if I could just drop these in!
best, b
« Last Edit: May 19, 2013, 02:31:49 AM by Neuronal »
Bob D
Reply #3 on: May 19, 2013, 11:39:52 AM
The 1uF cap - the one with the hole in the picture - is the parafeed cap. The coupling cap is 0.1uF; 0.2uF is an acceptable deviation for coupling in the SEX amp, but not for parafeed.
Otherwise, yes - no - yes - maybe. Mounting non-stock parts is often an issue, and always an issue you have to resolve yourself. That's part of the fun, right?!
Offline Neuronal
    • Datta Lab Website
Reply #4 on: May 19, 2013, 04:14:23 PM
Paul - thanks again (also for straightening me out about the parafeed and coupling caps - I have a 2 uF/600V cap I can use to replace the parafeed cap)!
I am almost certain to now have another problem, having replaced the blown Shottky diodes and replaced the parafeed caps. When I run the resistance checks it is perfect, and when I power it up the tubes glow and the thing plays music fine BUT...there is still a low level buzz coming out my transformer (same as before the diodes were blown), and the right tube is way hotter than the left. When I switch tubes the right tube is again way hotter (like too hot to touch within 30 seconds, whereas the left tube is just warm), meaning this is something about the circuit and not the the tube. I am taking voltages now, and will post them, but any preliminary thoughts would be appreciated....
Bob D
Reply #5 on: May 19, 2013, 04:31:02 PM
It sounds like the right side tube is not properly biased. That could be due to a bad cathode bypass capacitor. Start by remeasuring your voltages.
Offline Neuronal
    • Datta Lab Website
Reply #6 on: May 21, 2013, 04:07:30 PM
Total disaster.
I was measuring voltages, which seemed totally off anyways (f/e terminals 1 and 4 were in the millivolt range). When measuring 24 I shorted across my meter lead to 25 (I think - I thought that my hands were pretty steady); I heard a pop, and then most of the voltages went to zero. Fuse was intact, but now terminals 1 and 4 and pretty much all of the other terminals 1-40 read zero, and my tubes do not glow. My wife pulled me away from the rig before I could get any additional voltages (she thought I would be better at this with a night off), so I don't know the numbers for the transformer or C1-C5.  Any ideas as to where to start figuring out what went wrong? As you can tell I am totally new at this, but I would love it if I could fix this thing myself. I will recheck resistances tomorrow.
Back in med school I learned a word: iatrogenesis. It is when, in an attempt to fix things, we make them worse :(
« Last Edit: May 21, 2013, 04:16:52 PM by Neuronal »
Bob D
Reply #7 on: May 21, 2013, 06:28:16 PM
Start with transformer AC voltages.  They are measured by putting your Red/Black probes on the pairs of power transformer terminals.
Let us know if the values are about where they should be, though you may see some deviation for other reasons.
Offline Neuronal
    • Datta Lab Website
Reply #8 on: May 22, 2013, 01:06:06 AM
Thanks! Will do this and get right back!
Bob D
Offline Neuronal
    • Datta Lab Website
Reply #9 on: May 22, 2013, 05:24:26 PM
So ignore most of the last post: the short-circuit so scared me that I (a) had my meter on VAC the whole time and (b) put the fuse in wrong. Fuse in right, both tubes now glow with (L) tube relatively cold and (R) tube relatively hot.
Took voltages, transformer VACs were dead on, as were all the A side readings (which corresponds to the Right tube).
The B side (the one with the relatively cold tube) had lots of errors (if not indicated, reading was normal):
31 -6.8 VDC
36 -.7 VDC
B2 -.8 VDC
B5 -.8 VDC
and the plate choke on that side reads:
-.9 VDC for all terminals (1,4,5,8).
The C1-C5 is also normal (which, I hope, means I installed the new diodes correctly).
Any ideas? I assume I should be getting current through the plate choke so something must be wrong on that side :)
Thanks, again, to all of your for your patience and help - I'm hoping to level up as I learn to go through all of this.
best to all - b
Bob D
Reply #10 on: May 22, 2013, 05:38:40 PM
I would look for inconsistencies between the power supplies on each side.
Offline Neuronal
    • Datta Lab Website
Reply #11 on: May 22, 2013, 05:50:39 PM
Where do I look for/how do I identify those inconsistencies? Thx again - b
Bob D
Reply #12 on: May 22, 2013, 05:56:30 PM
Visually - since you have the older SEX amp, both power supplies should look roughly the same.
No voltage on any of the PC-2 terminals means that a ground connection is loose or missing, or another part to that power supply is awry.
The dysfunctional power supply is on terminals 21-30, the working one on the A side is 1-10.  You can compare voltages from side to side as well.
You have roughly 0V at 31/36, you'll need to see those bump up to 300+ for order to be restored.
Offline earwaxxer
Reply #13 on: May 22, 2013, 06:02:48 PM
Yes replace the cap... I didnt read any of what is written in this thread, but it doesnt matter. For us wacko's upgrading caps is like taking a dump. You dont think much about it. It comes natural.
Eric
Offline Neuronal
    • Datta Lab Website
Reply #14 on: May 22, 2013, 06:08:47 PM
Both sides look normal (nothing burned, loose or bulging), so I rechecked resistances, and they are normal throughout (would this be the case with a missing ground?). I also checked voltages to compare 1-10 and 21-30, and all are normal EXCEPT 26 is 466 VDC and 19 is Zero volts. 21 (233V) and 22 (233V) and 24 (220V) are also on the high side. So definitely something wrong with the power supply on that side - any suggestions as to how to proceed?
Bob D
