Installation of nylon stand off
mpent · 3799
Offline mpent
on: May 20, 2013, 04:45:23 AM
I am having a hell of a time trying to install the nylon standoff to the chassis for the C4S upgrade....can someone help?  Thank you.
Michael
Michael
Reply #1 on: May 20, 2013, 05:45:15 AM
Hello Michael,
Are you installing the C4S kit on the most recent SEX kit (2.1 - with Bottlehead PC-3 and OT-2 transformers?).
Did you remove the nut on the 5-lug terminal strip holding the two 220uF caps?  Is the standoff not fitting properly?
Offline mpent
Reply #2 on: May 20, 2013, 05:59:50 AM
Yes, 2.1 Sex Kit and yes, removed the nut.  Standoff is not fitting properly.
Michael
Reply #3 on: May 20, 2013, 06:33:13 AM
Is there a part that's in the way, or is it not threading on?
If it's not threading on, is it too large, or too small?
Offline mpent
Reply #4 on: May 20, 2013, 06:36:06 AM
Not threading on...too small.
Michael
Reply #5 on: May 20, 2013, 06:47:06 AM
Does the standoff thread onto the screw supplied with the C4S kit?
Offline mpent
Reply #6 on: May 20, 2013, 11:13:41 AM
yes, it does.
Michael
Reply #7 on: May 20, 2013, 11:18:53 AM
OK, as indicated in the instructions, this screw replaces the screw that holds on the central terminal strip.
Does the screw that you removed from the finished stock SEX amp not fit the standoff?
Offline mpent
Reply #8 on: May 20, 2013, 11:25:49 AM
Ok, I am a bit confused.  The instructions do not indicate to remove screw from chassis securing terminal strip.  It says to remove the nut from said screw, then install standoff. But yes, looks like the issue is that the screw currently securing the terminal strip is too large to fit the standoff.
Michael
Offline mpent
Reply #9 on: May 20, 2013, 11:35:45 AM
Ok, I think I am seeing my mistake now.  I de-nutted the screw from the wrong terminal.  I misinterpreted the instructions and disoriented the chassis configuration.  The instructions call for de-nutting the screw in front of the power transformer (terminals 1-5).  I de-nutted the screw from terminal exactly behind terminals 1-5 mistakenly...terminals 21-25?  I should be focusing on the "terminal strip" 1-5...instead I was misinterpreting and thinking I was focusing on terminal that was closest to the power transformer terminals 1-5.
Michael
Offline mpent
Reply #10 on: May 20, 2013, 11:38:22 AM
So...I am focusing on terminals 1-5, that which contains (2) 220uf capacitors as indicated in your previous post....sorry for the confusion.  From observation, that screw looks like it will properly thread.  Thanks for the second set of eyes....
Michael
Michael
Reply #11 on: May 20, 2013, 11:43:04 AM
No worries, I'm glad we could help!
Offline Tom-Huffman
Reply #12 on: May 20, 2013, 01:18:29 PM
I did the same exact thing - misinterpreted the location of the stand-off. It was obvious after I corrected it but not before.
Offline mpent
Reply #13 on: May 20, 2013, 01:26:26 PM
Yeah....I am definitely known to make such mistakes.  It's in there now and everything checks out proper.  Definitely tightened up the low frequencies. Loving it.
Michael
Michael
