Rustling sound when turning potmeter
manis · 3101
Offline manis
on: May 20, 2013, 07:35:00 PM
I'm hearing a slight rustling sound in my left speaker when turning the potmeter, between 6 and 7 o clock only. It has become noticeable after using the SEX 2.1 for 2 months now. The previous owner used it only a couple of months before me. The amp has been assembled at Bottlehead HQ, so I don't think it has anything to do with faulty construction.
Couple of questions:
-What is the problem?
-Will this get worse over time?
-Is this the result of the poor quality of the stock pot and less likely to happen if I put in a better one?
-Any suggestions as to replacement? brand/model etc.
> Macbook Air 13" late 2011
> Audirvana+ 1.4.6
> Supra USB 2.0 cable
> Jkenny Ciunas DAC 32/192
> Vermouth Audio Red Velvet ic
> Bottlehead S.E.X 2.1 (w/ C4S & imp.sw);
   Belden 19364 mains (w/ cryo Wattgate 320i IEC)
> Blue Jeans Cable 10 white (Belden)
> Blumenstein Orcas
Offline adamct
  • Maxxximum CAPacity Crack
Reply #1 on: May 20, 2013, 07:39:44 PM
1. Sounds like a problem with the volume pot.
2. Don't know.
3. Not sure i would stay the stock pot is of poor quality, but you may have gotten a defective one.
4. Use this: http://www.mouser.com/Search/ProductDetail.aspx?R=RK27112A0A16virtualkey68800000virtualkey688-RK27112A0A16
Best regards,
Adam
Reply #2 on: May 20, 2013, 11:53:40 PM
Often running the volume up and down will clean the oxidation from the carbon on the pot.  If this doesn't clean it, the next step is a spray cleaner like Deoxit.
If that doesn't help, and it should, then you get into which pot, do I use a stepped attenuator and which?
Offline earwaxxer
Reply #3 on: May 21, 2013, 04:11:26 AM
I'd upgrade the pot. It will sound better as well. As Granger was hinting at, the stepped pot is the best, but a log pot is more adjustable, but not the best sounding.
Eric
Reply #4 on: May 21, 2013, 04:41:55 AM
Just exercise the pot by twisting it 20 or 30 times.
Offline jimiclow
Reply #5 on: May 21, 2013, 05:00:08 AM
Spend $15 and get the Alps.
SEX 2.1- Alps, Mundorf
Stock Crack
Schiit Asgard, Schiit Lyr
Technics SL1200mkII
Woo WA-6
Offline adamct
Reply #6 on: May 21, 2013, 12:38:05 PM
If you decide to go for a stepped attenuator, then I would recommend the ladder-style ones from Vintage Audio Lab on eBay. Run a search for: "Valab 23 Step Ladder Type Attenuator Potentiometer 100K Log Stereo". Be sure not to limit your search to the U.S. only. I couldn't find any until I PM'd them. Turns out they had some listed in Australian dollars that weren't turning up in my search.
Best regards,
Adam
Offline manis
Reply #7 on: May 21, 2013, 07:17:30 PM
Thanks for all the tips, guys. It's amazing what a little trick like Doc prescribed does. I twisted my SEX knob (duh) 20-30 times and oh what a joy. The rustling sound is now almost inaudible. You really have to do your best to hear it.
> Audirvana+ 1.4.6
> Supra USB 2.0 cable
> Blumenstein Orcas
Reply #8 on: May 21, 2013, 11:49:40 PM
Try the spray for a better cleaning.
