ClarityCap SA 100uf 630V film caps on sale
adamct · 10567
Offline adamct
  • Maxxximum CAPacity Crack
on: May 22, 2013, 04:57:08 PM
MadiSound has 100uf ClarityCap SA 630V film caps on sale for only $40.17. By contrast, PartsConnection charges $87.62 for the same caps. But be warned, they are effing ENORMOUS.
Just thought I would pass this on for anyone who is interested...
Best,
Adam
Offline Natural Sound
Reply #1 on: May 22, 2013, 05:28:00 PM
Has anyone been successful at shoehorning a pair of these into a Crack/Speedball with the standard top plate and base?
Offline adamct
Reply #2 on: May 22, 2013, 05:32:59 PM
I fit a pair of 100uf ClarityCap ESA 250V caps into my Crack. I had to raise the case a bit, but it worked. The 100uf SA 630V caps look to be about the same diameter, but longer. I think they would fit.
EDIT: Disregard the above. I recently installed a pair of 100uf ClarityCap SA 630V caps in my Quickie, and had the chance to compare them to a 100uf ClarityCap ESA 250V. The SA 630V caps are considerably longer and wider. I'm no longer convinced they would fit in the case. ........but don't let that stop you from buying them! Figuring out a way to make oversized caps work in your build is a big part of the fun!
Best,
Adam
« Last Edit: June 11, 2013, 07:44:38 AM by adamct »
Reply #3 on: May 23, 2013, 11:58:20 AM
I need some 10uF@630V and they are $92.  I'll have to hold off a little longer.
Offline adamct
Reply #4 on: May 23, 2013, 01:14:29 PM
10uf 630V ESA ClarityCaps are only $19.67
Reply #5 on: May 23, 2013, 03:03:18 PM
I was looking at these:
http://www.madisoundspeakerstore.com/mr-cap-630vdc/claritycap-10.0-mfd-mr-range-polypropylene-caps/
Those were going into my Paramours with upgrade MQ iron.  Which page are you on?
Oh, wait!  You are looking at the ESA page.
Which is better, ESA or MR?
Offline johnsonad
Reply #6 on: May 23, 2013, 03:46:41 PM
MR
Offline adamct
Reply #7 on: May 23, 2013, 04:01:36 PM
In theory, the MRs are better. But it sounds as though most of the construction of both series is the same, with both reflecting the results of ClarityCap's research on reducing vibrations. The benefits of the MR sounded pretty limited to me, but what do I know...
In any case, Madisound won't carry the ESA 630V going forward, so this is a great chance to pick up some of those caps.
Best regards,
Adam
Reply #8 on: May 23, 2013, 06:04:33 PM
I am going to jump in here as well.
I am rebuilding my SR-45 with EXO-45 and Dowdy chokes. If I remember Paul"s formula correctly, I need a about a 10u parafeed cap.
I am currently using a 6.8 Obbligato with the old config and I am looking for a step up, or maybe just a change. Not going to spend stupid money...John
Reply #9 on: May 24, 2013, 12:03:44 AM
I may pop for the $40 caps today.  And maybe, down the line go for a higher priced cap.
Offline adamct
Reply #10 on: May 24, 2013, 02:01:07 AM
I bought one for my Quickie to replace the 1,000uf electrolytic. As a bonus, the SA ClarityCaps are red, as is my acrylic top plate. Hmmmmm.....maybe I'll mount the batteries on the underside, and the cap on top! That way I can hide the batteries, and show off the cap... ;D
Offline tsingle999
Reply #11 on: May 24, 2013, 05:19:20 AM
I got a pair of 12uf mrs for my sr45. Half off pcx pricing:)
Bottlehead Stat headphone amp
Reply #12 on: May 24, 2013, 09:59:59 AM
I did it, bought the lower priced cap.  Of course it cost more than the $8 I spent for the Obbligato Polypropylene Film/Oil caps 5+ years ago.
Opted for UPS delivery, $2 more than FedEx, because of FedEx's history of losing my shipments.  For a pair of caps Madisound should have a USPS option for ~$4.
Sometimes, even I, think I'm being too cheap!
« Last Edit: May 24, 2013, 10:53:35 AM by Grainger49 »
Offline corndog71
Reply #13 on: May 24, 2013, 11:32:03 AM
Both ESA and MR are great caps but there are differences between them.  The most notable is with ESA the uppermost treble is just a bit darker which makes for a very smooth and still detailed presentation.  The MR on the other hand is clean and clear top to bottom with excellent detail and dynamics.  In my sex amp I actually preferred the ESA because they better matched my AKG-702.  The MR's were a bit too revealing for those cans.
Rob
Offline denti alligator
Reply #14 on: May 24, 2013, 02:14:17 PM
Grainger, let me know how they compare to the Obbligato...
- Sam
