45 Parafeed cap,what value?
najo49 · 8398
Offline najo49
on: May 24, 2013, 03:16:54 AM
I have a 45 amp built by doc that I bought recently. In the original schematic from valve archives it gives the value of 10uf, for the parafeed cap but It has a 5uf sidereal cap . Any thoughts about this. I just sent for a 5uf mundorf supreme cap to try in  the sidereals place. Anyone have experience with this cap? also I am using the exo 45 opt,with the proper choke for this opt. Jan Ollsen
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Reply #1 on: May 24, 2013, 10:08:20 AM
My opinion is to break in the Mundorf before making any decisions.  They should get 100 hours, about 4 days + some, before installing.
Here is my post on Painless Break In:
Painless Break In Post
"Painless" because you don't listen to the cap going from Ok, to not so Ok, to good.
Offline johnsonad
Reply #2 on: May 24, 2013, 02:48:04 PM
That sidereal is a great cap! It was the first version of the auricaps. If you find something better, I'll give those a home :)
Reply #3 on: May 24, 2013, 04:32:21 PM
Got some references? I size parafeed caps by the plate choke inductance and OPT impedance, so I'd need both values to comment usefully. I know the EXO-45 is 5K, so I just need to know what the plate choke is. If you have the VALVE reference, that would help as well - might give a hint whether this was an exact copy of the published amp, or a variation with possibly different iron.
Reply #4 on: May 24, 2013, 07:22:29 PM
I don't remember this amp, and I sure don't remember the caps. It is quite possible that the 5uF caps were the best thing I had on hand when it was built - if I did actually build it. There are times when it is worth getting wrapped up in precision values for parts, like when you have to choose a resistor value to set a very precise amount of current through a component. But sizing parafeed caps to the last 1% is not necessarily one of those times. If the value is kept within a reasonable range, like 2:1 as opposed to 10:1, it simply shifts the LF rolloff few Hz.
Offline Natural Sound
Reply #5 on: May 25, 2013, 01:03:55 PM
Hi Paul, I'm wondering what size parafeed cap you would recommend when using an EXO-45 that is 5K and a DOWDY that is 125H?
(Paramour II using 45 output tubes. Not shunt regulated.)
Reply #6 on: May 25, 2013, 04:44:07 PM
10uF, or - as Doc says - anything from 5uF to 20uF.
Offline najo49
Reply #7 on: May 25, 2013, 04:56:55 PM
paul, the plate choke is a bcp 15 the opt and exo 45 .
Reply #8 on: May 25, 2013, 06:13:06 PM
The formula is 2 time inductance, divided by impedance squared.
BCP-15 comes with two different gaps and inductances, 40 or 50 henries at 50 or 40mA respectively. EXO-45 is a 5K primary. So 3.2 or 4uF - anything from half to twice is good enough.
Offline najo49
Reply #9 on: May 27, 2013, 12:00:24 PM
Grainger, Thanks for the reply on burn in. Is there any reason why you could not do 2 caps or even 3 in a string. I see not tech. reason why not?. j.olsen
Reply #10 on: May 28, 2013, 12:27:29 PM
If you put the caps in series the crossover gets higher and higher.  So no bass through them.  If you put them in parallel they get half the current.
Parallel is better but will take twice or three times as long depending on how many you parallel.
