Shunt regulator question
najo49 · 3980
Offline najo49
on: May 30, 2013, 07:34:37 AM
I removed the middle tube in my extended foreplay and noticed that music played even with it removed. Is this normal? Thanks jan Olsen
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Reply #1 on: May 30, 2013, 07:53:14 AM
You have defeated the voltage regulator by removing the tube. It is in parallel with the power supply, so the power supply will still supply voltage to the tubes. However you will find that the B+ at the inputs of the PC boards for the outer, preamp tubes is too high since the regulator is no longer controlling it. Running without it could require the C4S loads on the preamp tubes to dissipate too much excess voltage and they could run hot.
It also won't sound as good without the regulator.
