Hum pot
STURMJ · 3543
Offline STURMJ
on: June 06, 2013, 08:11:50 AM
So, I got my new Prebee working. ;D  I listened to it in a test position, not where I would place it in my system permanently and everything was beautiful.  Today I am moving things around and reconnecting where things will be from now on.
I decided to recheck the hum balance real quick. One of my pots has a bit of wiggle to it, causing unstable readings and "crumple-ly"noise to come out of the speaker.  I assume I need to replace this (probably both, if I can't get the exact match to the other one).  I did a quick search of my usual suppliers. and I guess I need more info on the pot.  Is it a 5W? I seem to remember seeing that it was (could be wrong). I found this to be the best match based on my not always good memory  ;)
http://www.mouser.com/ProductDetail/Alpha-Taiwan/VW24F-10-195K-B10/?qs=sGAEpiMZZMtC25l1F4XBU36uG75YKOIjzkV6wVcmq5U%3d
could you confirm that this will be acceptable before I order.
Also is it possible that this damaged anything? I had it on for about 2min before i noticed the wiggle-crackle-crumple connection.
Reply #1 on: June 06, 2013, 08:26:11 AM
You can get one from us, through [email protected]
Offline STURMJ
Reply #2 on: June 06, 2013, 08:29:17 AM
cool, and thanks
