Stereomour with DC heating
Follow the white rabbit · 6766
Offline Follow the white rabbit
on: June 09, 2013, 02:10:50 AM
Hi, I am being chased by higher hum...maybe 100Hz(germany).
Anyone fiddling around with DC for the heaters on for instance 45 tubes?
With a friend I built up a small test with some devices for regulated 2.5V and the hum was history. At least on one tube. We only tested the right side...
But I heard that the sound from the right speaker was not so loud as the left AC side...???
And the heater wire from the right tube didnt glow as strong as the left tube...
Some ideas? What about sound?
Reply #1 on: June 09, 2013, 02:45:11 AM
Alice,
I know that DC will give lower hum levels.  But I wonder why you are having a problem.  It could be that your speakers are very sensitive.  That reveals the low (1-2mV) hum of the Stereomour.
If that is the case then go for DC heaters.  The Paramounts use an inductor (Bottlehead designed) to smooth the DC for the heaters.  It is very quiet on 104dBW speakers.
« Last Edit: June 09, 2013, 02:26:59 PM by Grainger49 »
Reply #2 on: June 09, 2013, 04:51:36 AM
Hi, yes I do have over 100dB/W speakers. This is part of the problem... so, I will go on the DC path.
Thanks for your reply, grainger...
Reply #3 on: June 10, 2013, 01:11:17 AM
I will take a more modern approach to DC...I will post soon...
Reply #4 on: June 15, 2013, 08:42:18 PM
Hi Folks, we found that the power tubes(45s) built up the audible hum I had... so we did it!
AND now all is dead quite ...hahaha...exept for the music, now, creeping very spooky out of the silent background without unwanted noise!
We used two LT1085 - 7.5A, 5A, 3A Low Dropout Positive Adjustable Regulators
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fmy.funpic.de%2Fshow-photo%2F747731-PIC.jpg&hash=5171e1aeec769f674723408d941e694eaa2ffb8b)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fmy.funpic.de%2Fshow-photo%2F747732-PIC.jpg&hash=545fa663b93f75c5461eef699dd0d3b760c3a0c0)
Reply #5 on: June 16, 2013, 01:58:47 AM
That is the first time I have seen a volume knob on a power transformer.....
Beautiful work.  Do I understand that you triple regulated the heater power supply?  Nice move!
Reply #6 on: June 16, 2013, 07:21:56 AM
The Volume Knob is just a silencer! hahaha
The transformer top covering rang with a high tone after taking away the original heater wireing for the 45 tubes... !!!  :)
Sorry for the confusion! There is no triple regulation! hahaha
We used a separate power transformer with two 6 V secondaries (3A
each), and for each filament supply a Schottky rectifier bridge, a
10000u capacitor and an LT1085 regulator providing 2.5V. For good
measure, we added a soft-start circuit.  Interestingly enough, the (EI
core) power transformer had to be widely separated from the plate
chokes and output transformers (speakers: way beyond 100 dB) to avoid direct
coupling (which was quite audible even with about 5 inches of
separation).
« Last Edit: June 16, 2013, 07:24:17 AM by Follow the white rabbit »
Offline howardnair
Reply #7 on: June 16, 2013, 08:58:02 AM
if one were to put lead-coated copper shields between or around a transformer/transformers  would this do anything to alleviate any coupling from one to the other?
Reply #8 on: June 16, 2013, 09:38:05 AM
I once put a small transformer and some bridge rectifiers in tin cans... did a great job defensing unwanted noise...
But lead coated copper shields?...donoh... try and error...
Reply #9 on: June 16, 2013, 10:25:06 AM
Why don't you put a resistor across the unused filament winding, add a bit of load...John
Online Paul Joppa
Reply #10 on: June 16, 2013, 03:19:59 PM
To prevent magnetic hum coupling (the most likely source) you must use magnetic material, preferably with a high permeability. Soft iron pipe has been used by amateurs (better than steel) - at least it's think! - but nickel alloys such as permalloy, molyperm", mumetal, etc. are the reference standard.
Reply #11 on: June 19, 2013, 09:50:45 PM
Finally I realized that a second switch for the first heating of the cathode filament would be a good idea...
http://koti.mbnet.fi/siliconf/JukkaTolonen/ga/amptimer/amptimer.html
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fmy.funpic.de%2Fshow-photo%2F748627-PIC.jpg&hash=3bd101cc361cabfa741339895ef0cf26aab119ce)
Happy listening!  ;D
Reply #12 on: June 20, 2013, 12:02:33 AM
Alice,
Great!  This will baby your tubes.
BTW, those are awfully cool looking, which are they?
Reply #13 on: June 20, 2013, 01:22:15 AM
Sophia Electric 45 mesh plate. I just thought I should give them a try...
In comparement to some 45's from Rogers I can say that the Sophias have a little more width in soundstage...sometimes I feel the musicians are stretched to an unnatural width... :o
The Rogers tubes have a little more natural inward fokasing.
Both sound very rich! I like the pings the tubes make warming up in the first 3-4sec. ting...ping...ting... ;D
Their plant is in Virginia I think...
http://www.sophiaelectric.com/
Maybe someone has interest? http://www.shinelimited.co.nz/work/the-becks-edison-bottle
Offline galyons
  • Geary Lyons
Reply #14 on: June 20, 2013, 06:13:55 AM
Sophia Electric 45 mesh plate...
Sophia is another "label" for Chinese tubes and equipment. Sohpia is located in Virginia. They likely don't make anything.  The tubes are made  by TJ Full Music. The Chinese plant makes them, quite well, I might add!  That being said, I have a pair and like them very much.
My favorite 45's are a pair of 1937 vintage RCA Radiotrons  They just have a wonderful sound.  The Sophia's get everyday use, as they are replaceable. My OS 45's get played on occasions when I am dedicated to listening.
It is wonderful that new stock 45's are being produced, especially at high quality levels!
Geary
« Last Edit: June 20, 2013, 10:49:05 AM by galyons »
