Paramount voltage problems? All help appreciated
docbob52 · 3494
Offline docbob52
on: June 09, 2013, 09:20:22 AM
I was about to listen to the Paramounts but I noted several voltage discrepancies:
Terminal should be / Is
6: 0/ 75
10: 233/ 0
11: 164/ 231
12: 0/ 163 A amp and 126 B amp
13: 94/ 0 and this terminal in the manual has no connections so I think this is a misprint
Resistances were all ok except
9: 124k/ 292k A amp
Garrard 301/ high mass plinth, SME 312S tonearm/ Sleeping beauty cartridge/ Denon AU 320SUT. Transcendent audio GG preamp and OTL SOB power amp. Blumenstein Orca/Dungeness Speakers
Second system.  BH Paramount 300B amps.  BeePre.  Sony SCD777ES, Wyred4 sound Dac. Mac mini.
Reply #1 on: June 09, 2013, 07:47:33 PM
There were some issues with the voltage measurements in the Paramount 1.1 manual. I've fixed them and revamped the tests for the manual. There is a sticky post at the top of this forum that goes over the new measurements. I seem to recall terminal ten was one of the more troublesome. Try those new tests and post back if you still have discrepancies.
Offline docbob52
Reply #2 on: June 10, 2013, 01:24:40 PM
Josh,
That takes care of terminal 10 being 0 as it was on my assessment.  I still have the following discrepancies that are greater 15%
6: 0/ 75
11: 164/ 231
12: 0/ 163 on the A amp and 126 on the B amp
13: 94/ 0
Resistances were all ok except:
9: 124k/ 292k on the  A amp, the B amp was normal.
All help appreciated.
« Last Edit: June 11, 2013, 11:59:18 AM by docbob52 »
