new iron upgrade in original sex monos?
najo49 · 3927
Offline najo49
on: June 17, 2013, 06:06:40 AM
would it be possible to put the new iron upgrade in the original sex amps. I know I would probably have to change the power tranny also. But would it be possible to put the new sex design in these and get monos,with new iron?Jan Olsen
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Reply #1 on: June 18, 2013, 02:41:07 AM
No. The plate choke cannot handle the necessary 60mA, and the 4K transformer impedance is a little high - 3K is better. I am hoping to have a better plate choke eventually, but meanwhile you could use the Hammond 158L choke with a Bottlehead OT-1 or Magnequest TFA 2004Jr.
I have a draft article on the Original SEX and its options, not yet edited. I'm out of town right now, but if you want a draft, send a PM with your email address and I'll send a copy next week.
