Non Extended FPIII Output Caps 3.0uf 200v OK?
mike9186 · 4427
Offline mike9186
on: June 18, 2013, 05:28:05 PM
I just pulled my non-extended FPIII off the shelf and installed some 6CG7's (BTW, in my system I'm not hearing a dramatic difference from the RCA Clears I've had in there for years). I have some old PIO caps that are 2.0uf 200v and tried some Auricaps that I had in a box that are 3.0uf 200v. It sounds fine albeit a little bright (but that could be my speakers more than the preamp and Paramours)
Is this OK or should I use 250v caps that are spec'ed for the non extended FPIII?
I've been out of the Bottlehead world for a long time so the help is greatly appreciated.
-Mike B
Reply #1 on: June 19, 2013, 06:21:56 AM
200V is plenty for the FP-III.
I would even be comfortable running 150V caps on a stock FP-III.
Offline mike9186
Reply #2 on: June 19, 2013, 06:39:32 AM
Thanks PB! That is what I thought but wanted to check with the group.
All the best
Mike B
