Capacitor "divot"
azrockitman · 2464
Offline azrockitman
on: June 27, 2013, 07:00:21 AM
I brushed against one of the large black capacitors on my stereomour kit with my soldering iron shaft. Needless to say, I left a nice little divot on the capacitor housing.  Should I replace it now? Or is it likely fine/unharmed?  No guts or blood appears to be oozing out.  But if I likely did real harm,I'd rather cut my losses now rather than have to pull it out when I'm 100% done.   Any suggestions would be appreciated.   Thanks.
Esoteric DV-50, Technics SL1200-M3D, B&K Phono 10 Preamp, Sumiko Blue Point Special Evo III, Bottlehead Stereomour, Orca's
Offline HF9
  • Zynsonix.com
    • Zynsonix.com
Reply #1 on: June 27, 2013, 07:08:03 AM
Was it a film cap or electrolytic? You may want to post a picture. Seeing the "divot" should allow us to ascertain if it's still usable. Even if you did knick it good, the cost to replace is only a few $$.
« Last Edit: June 27, 2013, 07:09:34 AM by HF9 »
Offline azrockitman
Reply #2 on: June 27, 2013, 07:30:32 AM
It's one of the 220uF 250V electrolytic capacitors
I'll try to post a pic shortly.
Online Doc B.
Reply #3 on: June 27, 2013, 07:43:57 AM
If you just melted the plastic cover with a hot iron there is no problem. If you dented the metal can underneath it should be replaced.
Offline azrockitman
Reply #4 on: June 27, 2013, 08:31:43 AM
the metal is exposed, but not sure if it's damaged or not
4krow
Reply #5 on: June 27, 2013, 10:43:54 AM
Yah, at 52kb it's pretty hard to tell  maybe at 200-300kb it would show up.
Offline azrockitman
Reply #6 on: June 27, 2013, 01:19:01 PM
I had to keep reducing the size of the photo to get it to send.  But Doc took a look at it and thought it looked ok so I'm moving forward with fingers crossed.  Thanks.
Reply #7 on: June 27, 2013, 01:43:25 PM
Those electrolytics are tough, I wouldn't worry too much about it.
(Sorry I didn't see your e-mail until now)
