stereomour 2A3's not glowing
azrockitman · 10789
Offline azrockitman
on: June 29, 2013, 08:18:23 AM
So I completed my kit last night, did a resistance check, everything looked super, so I bypassed the voltage check and went straight to moment of glory.  but no glory.  The little single 12AT7 sylvania tube began glowing promptly but the 2A3's did not.  So I waited a few minutes to make sure I didn't see or hear (or smell   ;)   )any other issues and then powered it down.
So I'm going to go back and do the voltage check but I"m curious about two things:
1)  Do those large tubes glow like the traditional tube?
2)  Does the fact that the little single tube has power... point to any specific red flag that would help me zero in on something?
As I said, I'll complete the voltage check and make notes and see what that tells me but I thought I would see if this "smells" like one particular issue or not.  Thanks
Esoteric DV-50, Technics SL1200-M3D, B&K Phono 10 Preamp, Sumiko Blue Point Special Evo III, Bottlehead Stereomour, Orca's
Offline mpeg2
Reply #1 on: June 29, 2013, 08:20:37 AM
The filaments on the 2A3s are really hard to see - especially in room light. If you turn off the lights & look directly down on the tube you'll see 3 (or 4) dimly glowing spots on top).
   Rich
Offline azrockitman
Reply #2 on: June 29, 2013, 08:34:00 AM
Thanks MPEG2.....that made my morning!  I expected those puppies to glow like my s.e.x. kit tubes but was very discouraged to see nothing.  I"ll complete the check and then power it back up.  Thanks again.
Offline azrockitman
Reply #3 on: June 29, 2013, 09:07:26 AM
I couldn't resist, so I reconnected a sound source and speakers but no sound.  I also didn't think to check earlier but the 2A3's aren't getting warm either so they aren't getting power.  So it's back to the voltage check.
Reply #4 on: June 29, 2013, 10:56:19 AM
There is a frequent mistake.  Several Bottleheads have plugged the 2A3 tubes in wrong.  If you don't get the right voltage to the cathode/heater it won't work.  Check the orientation of the tubes.  Then check the orientation of the sockets.
Post back.
Offline azrockitman
Reply #5 on: June 29, 2013, 12:31:28 PM
First, Grainger;  I've got both sockets mounted with the larger holes in back next to the hum pots.  Tubes are mounted also with larger pins in the back.  Underside, wiring matches the instructions and finished photo, per my eyes, so I don't think I've messed that up but here are my voltages...they may prove otherwise:
1   411
2   0.810
3   0
4   0
5   0
6   0
7   0
8   0
9   0
10 0
11 0
12 0
13 0
14 203.7
15 410
16  won't settle
17 411
18 won't settle
19 411
20 won't settle
A1 won't settle
A2 410
A3 0
A4 0
C1 0
C2 412
C3 0
C4 0
IA 409
IB 411
OA  0.8
OB 203.8
KREG 2.8 A SIDE
KREG 2.5 B
-REG 0
-REG 0
Clearly some missing/wrong voltages.   FYI "won't settle"   my suspicion is that my meter it responding in the same way on these terminals as if I was just waiving the pin around in the air attached to nothing.  My meter does that as I'm moving into location with the pin.  Once connected to something, it settles and give me a voltage.   but in the case of the "wont settle" it just keeps behaving as if I never touched the red terminal pin to anything.
Offline jimiclow
Reply #6 on: June 29, 2013, 03:48:45 PM
Set your voltmeter to AC and measure voltages across A1/A4, C1/C4 and see if the filaments are getting power.
Bottlehead Stereomour with V-cap, Mundorf, Alps
SEX 2.1- Alps, Mundorf
Stock Crack
Reduction with Mundorf, Clarity caps
Schiit Asgard, Schiit Lyr
Technics SL1200mkII
Woo WA-6
Hoyt-Bedford speakers, Fostex T90A
LCD-2, HD600, ER4P, HF5, SR60i, DT990-600, DT770-32, HFI580
Offline azrockitman
Reply #7 on: June 29, 2013, 07:48:22 PM
I'm getting zero on the A's
2.36 on the C's.
Offline jimiclow
Reply #8 on: June 29, 2013, 09:20:56 PM
The C side should warm up as it's getting power.
Re-trace the heater wires on A side, check the transformer taps if you have power. There's probably a cold solder on that side.
Stock Crack
Technics SL1200mkII
Woo WA-6
Reply #9 on: June 30, 2013, 02:09:16 AM
I expect the Stereomour transformer has only one 2.5V AC heater winding.  So if one channel has the voltage and the other doesn't there is an iffy solder joint between the two.
Of course I could be wrong, and there might be two heater windings on the transformer.  In that case yo check from the transformer forward to the tube to see where the voltage disappears.
Reply #10 on: June 30, 2013, 04:38:34 AM
There are two 2.5v windings. It's necessary to allow the tubes to bias independently.
Reply #11 on: June 30, 2013, 06:03:41 AM
D'oh,  I forgot about the heaters being the cathodes.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FSmiles%2FSlapHead.gif&hash=e5c580c3cfdf525c26703ae0328aefb586b04de5)
Offline azrockitman
Reply #12 on: June 30, 2013, 09:54:46 AM
So clearly I have a right channel (A side) power issue. But I noticed no warmth out of the left channel tube when I had the unit powered up for a few minutes.  Do these tubes not warm to the touch as much as other tubes.  Or are they slow to warm?
If so, that might explain no warmth out of that tube for the few minutes it was turned on. .  I also might see if either tube powers up on that side....maybe one of the tubes is bad...?
Reply #13 on: June 30, 2013, 09:58:29 AM
Trace the red/black pair of wires back to the transformer that feed socket C.  I would bet on a loose connection at the power transformer.
In either case, neither of your 2A3's are drawing any current, but it would be nice to know that they are both heating.
You also have an issue in your driver stage, the OA pad is showing a short to ground, I'd double check that there are no miswires on or under the PC board, and that all the transistors are mounted consistently from side to side.
Offline azrockitman
Reply #14 on: July 01, 2013, 06:36:53 PM
Paul, did you mean C or A?  (because I was getting 2.36 v out of the C's when I checked them previously...it was the A's with zero)
But that aside, You are talking about the connection from the power transformer terminals 12/red to C4 and 13/black to C1, correct?  If so, I have continuity from past both terminals on the power transformer (I'm touching the little "solder nubile" that sticks out on each terminal on both sides of the transformer) to also past the C1 and C4 terminals on the C socket.  In other words, I'm not touching any part of the actual wire, so to me that confirms a good solder since continuity is achieved outside of the wire or the solder itself.
Now, on the other hand, I also checked the same on the A socket.....and while the black wire has continuity past both ends of the wire, the Red wire does not. I have continuity from the A1 socket terminal and all around that solder itself, but The red is dead on the terminal 11 on the power transformer side....I do not have continuity there.
So that being the case, should I simply try to resolder that connection on 11 on the power transformer?
