Waiting for the price of that pricey cap/wire/whatever to come down?
Downhome Upstate · 18017
Offline earwaxxer
Thanks for the info Cliff - I'll have to put that mod on my short list!
Eric
4krow
  Cliff,   The idea of using Elna is solid. If one would only fit into my integrated. I think that I might be doing some measuring before the nights over. The Elna single deck might just work.
Offline chard
Eric and Greg, One thing I did was take a 1" x 1" 1/2 board and made a six eyelet board. I took apart a terminal strip removing all metal parts except the foot that bolts to the chassis and enough board to glue to the eyelet board. This gave me have an upright eyelet board with eyelets in about the same position as the pot eyelets. This allowed me to disconnect the selector switch shielded cables and input shielded cables from the pot and solder them to the eyelet board instead. By doing this I didn't have to redo any of the shielded cable other then disconnecting it from the pot and soldering it to the eyelet board instead.
  I used two 4 terminal, terminal strips positioned on either side of the switch about 1 inch from the switch to connect the shunt resisters to ground.
Clifford Hard
The job is coming to an end.  I have to make a decision.  Where do I want to put some high $ caps?  The Eros has 0.47uF Mundorf Silver/Gold/Oil, the FP 2 has 0.47uF Mundorf Silver/Oil, the Paramours have four caps waiting to be installed (Mundorf Silver/Oil and Clarity caps).
So where do I want to change it up?  I seem to have too small a cap in the FP 2.  It should be 2uF or larger, I could have been under the influence for that order.
Any suggestions?  The cash is going to run out in 5 weeks!
Offline corndog71
Try a pair of Sonicap Gen 1.  You can get a matched pair from Sonicraft.com
Rob
For what piece?
Offline corndog71
For what piece?
For the FP 2.  Not too spendy either.
Rob
Offline earwaxxer
2uF or higher.... I assume you need two, that could get pricey, but a good size to have on hand. I honestly recommend the Mundorf silver/oil in that size. I have four of those in the 2.2uF. They come in handy. I think the Mundorf silver/oil is a better value over the silver/gold/oil. I think it's the smart choice in lew of a Duelund or V-cap... I know, you're prob looking for some sexy new bitch. Sometimes it's good to stay with what you know!
Eric
Offline johnsonad
Eric has got a good point, stick with what you know and like.  I'm going out on a limb with the Jupiters but every once in a while you need to do that, right?
Offline earwaxxer
Cool! Can't wait to hear what you think
Eric
Rob,
Got you now.  The Sonicaps are downright cheap.  I have had them bookmarked for ages and never done anything with it.
I can buy those and a pair of Mundorfs.  I'll do that.
Offline earwaxxer
Granger - you will have to let us know about the Sonicaps - they get very little press, they could be a sleeper value
Eric
Yup, I'll send myself a link at work to order tomorrow.
Offline tsingle999
Well i definitely like the clarity cap mr as a parafeed cap over the mundorf supreme or auricap. Very detailed and spacious bringing a little more life too. Thanks to Deb for the initial recommendation. Thanks to parts express to be out of stock when i ordered and then madisound for having them half price a short time later!
Bottlehead Stat headphone amp
Offline earwaxxer
 Very curious about the MR!
Eric
