Left static
Guest · 5416
audiophileboss
on: July 23, 2013, 02:42:48 PM
I just assembled a crack, speedball to be done soon. There is a static in the left channel at times. When i wiggle the phono plug in the phono jack it is more present. Advice?
Offline John EH
Reply #1 on: July 23, 2013, 03:44:15 PM
When you say at times, what times?  Only when you move the headphone cable?
Have you by chance tried another pair of headphones to see if it is the cable in the headphones?  That is the first thing you need to eliminate before you start troubleshooting.
John
Reply #2 on: July 23, 2013, 03:45:29 PM
Try wetting the solder joints on the headphone jack a little bit, as well as the red and white wires that depart from the jack.
Reply #3 on: July 24, 2013, 12:11:53 AM
I have had interconnects where the outer shield got loose over the years.  I just gently pinched them in so the were again tight.
Try this after rewetting the solder joints as PB suggests.
audiophileboss
Reply #4 on: July 24, 2013, 12:42:57 AM
Yes, by times i mean when I the cable moves or if the phono moves
Tried the cans on a different peice of equipment and it didnt do that. lol the only other cans I have are 32ohms
audiophileboss
Reply #5 on: July 24, 2013, 08:19:52 AM
So its not the cable. I rewetted all the solder joints on the left channel and especially on the phono jack. Same problem. Any help?
Offline John EH
Reply #6 on: July 24, 2013, 10:49:53 AM
Speedball is installed?  Are are the LED's lit?
audiophileboss
Reply #7 on: July 24, 2013, 10:51:24 AM
Speedball not installed. But the leds by the 12auf are working
Reply #8 on: July 24, 2013, 10:57:57 AM
A-B,
You are narrowing it down.  Don't give up hope!
The problem seems to be around the RCA jack and interconnect.
Can you try some experiments of wiggling other things (on the amp, not your things ;)) to see what else might be involved?
P.S. it would be nice to have at least a first name to call you, not the abbreviation for Allen-Bradley.
audiophileboss
Reply #9 on: July 24, 2013, 01:35:57 PM
Sure, Matt
So I resoldered the left rca connections and all most white wire. I did not check the left channel resistors or capacitors.
Question: did you guys put solder on ALL of the holes on the phono jack? I only soldered those that had wires on it
Reply #10 on: July 24, 2013, 02:38:11 PM
IIRC, the phono input jack has two connections.  The center one is the signal.  The outer shell is the ground.  Without the ground it hums.  Without the signal it makes no sound.
audiophileboss
Reply #11 on: July 27, 2013, 01:02:06 AM
Ok but should I solder any other of the holes on the phono jack? Or any other suggestions you guys may have?
Reply #12 on: July 27, 2013, 03:11:38 AM
I'm saying that there are only two holes on RCA jacks.  Both must be soldered in the case of the input jacks.
Do you mean the headphone jack?
audiophileboss
Reply #13 on: July 27, 2013, 06:40:46 AM
Yes the phono jack.
Reply #14 on: July 27, 2013, 06:43:30 AM
I'm confused.  I asked if you meant the headphone jack and you replied, yes the phono jack.  The inputs are RCA jacks, the output is a Phone jack.
What do you mean?  The input or output?
