General Category
General Discussion
Cathode capacitor, do I need one?
fdandrews
3998
fdandrews
Newbie
February 09, 2010, 05:14:38 AM
Hi! I'm in the middle of building a parallel feed amp with a 6W6 output tube and cathode bias. I plan to use it only above 100hz in a biamped system. Does the cathode resistor still need a capacitor across it? Can I leave it out to reduce the low frequency signal going to the main speakers?
Global Moderator
Hero Member
Re: Cathode capacitor, do I need one?
Reply #1 on:
February 09, 2010, 07:12:26 AM
That would probably work well. Return the output transformer to the cathode, not to ground, so that the bias resistor is not part of the midband signal current loop.
General Category
General Discussion
