Vaic Valve 30B
RPMac · 4210
Offline RPMac
on: July 28, 2013, 06:25:58 AM
Will the Vaic Valve 30B work in the BeePre?
Reply #1 on: July 28, 2013, 06:30:41 AM
It may have addittional current draw similar to the EML.  You can drop the tube in, then measure the voltage across the two 8 Ohm cathode resistors, looking to see about 5V across each.  If necessary, these resistors can be adjusted to restore this voltage balance.
