Bottlehead Kits
Eros Phono
Eros Faceplate powdercoated
azrockitman
3314
azrockitman
Full Member
August 03, 2013, 10:23:50 AM
Ok, i can't help myself, I like the look.
But I need to know where I need to grind down to bare metal so everything is grounded correctly before I start. Both sides of the panel are powdercoated. Thanks!
Esoteric DV-50, Technics SL1200-M3D, B&K Phono 10 Preamp, Sumiko Blue Point Special Evo III, Bottlehead Stereomour, Orca's
johnsonad
Hero Member
Re: Eros Faceplate powdercoated
Reply #1 on:
August 03, 2013, 10:30:58 AM
For the chassis ground (star grounds), I used a small flat head screw driver to cut down to metal on my powder coated plates and I've had zero hum issues.
azrockitman
Full Member
Reply #2 on:
August 04, 2013, 03:20:29 PM
Thanks Aaron, I appreciate it!
HF9
Sr. Member
Zynsonix.com
Reply #3 on:
August 04, 2013, 05:57:32 PM
Generally, even without sanding down, I've almost always had a solid plate connection using locking washers as they dig through the finish to some degree (testing for resistance between the screw and ground), however to be extra sure there's a good contact, I like to use a dremel tool with a metal bit to sand away the area.
Another note, powdercoaters often handle electronic equipment and have little heat resistant stickers they can put wherever you have a ground connection, like this:
http://www.diyaudioblog.com/2013/04/audio-note-dac-21-level-b.html
My DIY Audio Electronics Blog:
DIYAudioBlog.com
azrockitman
Full Member
Reply #4 on:
August 04, 2013, 08:12:48 PM
HF9, great info. Helped in a couple of ways. Thanks!
Bottlehead Kits
Eros Phono
