Twin Plate load/servo pc boards-construction tip
azrockitman · 3178
Offline azrockitman
on: August 06, 2013, 08:11:12 PM
I'm curious if there is a strong consensus on whether to build both boards at the same time, or build one, then the other.
Logic leads me to construct both boards simultaneously, since they are twins.  If I'm carefully following instructions, it seems like the chance for error would be lower by completing each step twice simultaneously; conversely I would think the chance for error higher if I was needing to read through those same instructions on two different occasions.
Esoteric DV-50, Technics SL1200-M3D, B&K Phono 10 Preamp, Sumiko Blue Point Special Evo III, Bottlehead Stereomour, Orca's
Reply #1 on: August 06, 2013, 11:17:34 PM
I built one at a time.  I think I took 6 or 7 short build evenings to build my Eros.  It was relaxing doing just a little at a time.  BTW, I built completely stock to begin with then after 2 months tried some capacitor rolling with jumpers.
Reply #2 on: August 07, 2013, 05:55:12 AM
The chance for making the same error twice is much higher.
Offline azrockitman
Reply #3 on: August 07, 2013, 10:05:45 AM
Looks like it's unanimous.   :)  One at a time it is. Thanks
