Replacing the last power supply cap
adamct · 24198
Offline adamct
  • Maxxximum CAPacity Crack
Reply #60 on: August 15, 2013, 03:28:49 PM
The cap has one terminal on one end, and two terminals on the other end. Do that mean anything?
Offline adamct
Reply #61 on: August 15, 2013, 03:42:32 PM
Well, I now know it is metalized polypropylene, and I know it is DC rated. I also know it is not a motor start cap. So the only open question is whether it matters that it has two terminals on one side...
Offline adamct
Reply #62 on: August 15, 2013, 04:43:53 PM
Hmmmm...could it be an HVAC cap? If so, any reason not to use one?
Reply #63 on: August 15, 2013, 04:44:35 PM
That could be a terminal, or just a mounting stud, but the datasheet you linked to isn't very specific.  It would seem reasonable that the bottom stud is not connected internally, especially since this is a motor run cap.
Offline adamct
Reply #64 on: August 15, 2013, 04:57:36 PM
Thanks. Here is a picture. I think I'll buy a couple and try them out...
Just to confirm: it is OK to replace the 220uf electrolytics in the power supply with 200uf film caps, right? Would a 250uf cap be better?
Best,
Adam
Reply #65 on: August 15, 2013, 05:32:38 PM
The ebay listing says 420vDC but the data sheet says 420vAC. The data sheet says metalized but does not say what is metalized - polyester, polypropylene, dried snot, kleenex, who knows?! The maximum 5kHz frequency makes me suspect it might not be polypropylene - not clear why you "now know it is ..."?!
Sorry, I'm just a suspicious SOB. It's cheap, give it a try - the worst that can happen is a blown fuse, and a REAL Bottlehead buys them by the gross at Costco!  :^)
Reply #66 on: August 15, 2013, 05:36:28 PM
200uf should be close enough. The data sheet calls out a "Fixing stud"
fixing: Stud M 12 x 16 mm
Maximum torque (fixing) 10 Nm
Case Material :
Offline adamct
Reply #67 on: August 15, 2013, 05:38:48 PM
I found this data sheet, which shows they are polypropylene. I agree it is odd that the data sheet doesn't mention the DC rating, but the label on the cap itself does show a DC rating (you can see it if you enlarge the picture in the eBay listing). The seller confirmed that they aren't motor start caps.
Offline adamct
Reply #68 on: August 15, 2013, 05:39:31 PM
Case Material :
Great. Thanks, John.
Offline adamct
Reply #69 on: August 15, 2013, 05:53:55 PM
Well, I've now got four of them on the way to me. Worst comes to worst, I can add them to my growing collection of unsuitable 200uf caps. I recently received a call from a dealer in Miami, who said he had an eccentric client with a pair of mint, 200uf metalized Kleenex caps available for the right price. Apparently these are fairly unusual, since they still have pieces of vintage snot on them. I'm afraid I won't be able to resist that siren song. The second mortgage on my house should be approved any day now, and then those caps WILL be mine!
Reply #70 on: August 15, 2013, 07:31:57 PM
Hey PJ,
If I roll you some copper foil/kleenex caps and pot them in mineral oil, can I put them in your BeePre? ;)
Reply #71 on: August 16, 2013, 06:08:58 AM
That's what we call PB when he's doing repairs for customers.
Offline galyons
  • Geary Lyons
Reply #72 on: August 16, 2013, 08:25:35 AM
+1   ;D
Cheers,
Geary
Reply #73 on: August 16, 2013, 05:29:43 PM
I still offer my, Earwax impregnated, Gum wrapper caps.
Available in copper or Spearmint...John
Offline adamct
Reply #74 on: August 22, 2013, 03:48:50 PM
So the 200uf Icar caps arrived today.
THEY.
ARE.
MASSIVE!!!
We will see how they perform, but they make me laugh just looking at them. Here is my question: the terminals are massive bolts with chunky nuts that screw onto them. I'm trying to envision myself soldering leads onto there, and I just don't see it happening. I've got to believe my soldering iron would just lie down and call "Uncle". Any advice? Should I try it anyway? Or do you think I can/should just wrap the stripped tip of the lead onto the terminal and cinch down the bolt? Is a physical connection enough here?
I'm cautious about attempting to solder leads on, as I don't want to get solder in the terminal threads and thereby render it impossible to screw a bolt on if I need to.
Pictures to follow when I get a chance...
Best,
Adam
