Need Nut Holders-- Not Jock Straps
docbob52 · 5059
Offline docbob52
on: August 10, 2013, 01:26:34 PM
Back in the 60's when I was 13,  I built a 29 tube Knight Kit SW receiver the kit was supplied with several delrin plastic nut holders.  They were made like 3" nut drivers with different sizes at each end and would allow you to pick up and secure a nut for placement over a screw.  This was great in tight places and greatly facilitated  construction.  It stopped all the fumbling and made it easy to start a nut over a skew.
Does anyone know if these are available now from any parts houses?
« Last Edit: August 10, 2013, 02:03:24 PM by docbob52 »
Garrard 301/ high mass plinth, SME 312S tonearm/ Sleeping beauty cartridge/ Denon AU 320SUT. Transcendent audio GG preamp and OTL SOB power amp. Blumenstein Orca/Dungeness Speakers
Second system.  BH Paramount 300B amps.  BeePre.  Sony SCD777ES, Wyred4 sound Dac. Mac mini.
Reply #1 on: August 10, 2013, 07:31:10 PM
I have seen some plastic nut drivers from Stanley, and also some metal jewelers' type nut drivers from random manufacturers.
Reply #2 on: August 11, 2013, 06:07:42 PM
I got this from Parts Express a few years ago, is the perfect thing for 1/4, 4-40 nuts, don't know if they still have them.
Go through your collection of cheep ball point pens, I found a barrel on one that holds a 3/8. nut almost as well. In a pinch you can tape a nut to the eraser of a pencil or something...John
Offline Tubejack
Reply #3 on: August 12, 2013, 02:20:35 AM
I use these, small nut starters (and similar screw starters).  http://www.ebay.com/itm/Ullman-G2-Nut-Starter-/170946687796?pt=LH_DefaultDomain_0&hash=item27cd377334.
My other hobby is a HO train layout that uses a lot of #4, #2, and smaller screws/nuts on the loco's and car bodies, and electronic DCC components.  They can be found at hobby shops, Hobby Lobby, Micro Mart, or on the www.
There are 10 types of people in this world,
Those that understand Binary and those that Don't!
Offline docbob52
Reply #4 on: January 26, 2015, 01:11:26 PM
Thanks guy's for all the help.  Just invented a low tech solution.  A toothpick with a bit of Blue Tac.  Works like a charm especially for mounting nuts on phono cartridges, which can be a bitch
