remote to this amp?
davidro · 6924
Offline Sh7eleven
Reply #15 on: August 14, 2013, 03:10:11 AM
You can build one.  Like Adamct, I am also a lawyer and had neither built any electronics nor soldered before. In fact, I'd never even seen anyone solder before.  I first built the foreplay III, then a couple years later a crack, and I just finished a stereomour a few months ago.  If you're intimidated by putting together a stereomour, I would highly recommend building a crack - its a great intro to all the basics needed for the other kits.
Sean Hamill
music, ski, music
Stereomour
Crack
FPIII extended
Offline adamct
  • Maxxximum CAPacity Crack
Reply #16 on: August 14, 2013, 03:44:16 AM
Or you could also go for a Quickie, if headphones aren't your thing. If the Crack is a Level 1, the Quickie should really be a level 0.5!
And at only $99, you can't really ask for a cheaper entry point into this hobby...
Offline davidro
Reply #17 on: August 18, 2013, 03:58:49 PM
Thanks guys. I ended up buying a secondhand SET which was locally made. I might consider building my own in future again.
Cheers
D
Offline Mike B
Reply #18 on: August 18, 2013, 04:54:43 PM
Does it have a remote control?
Offline davidro
Reply #19 on: August 18, 2013, 06:44:28 PM
Unfortunately no. I'm learning to live without it. Luckily the sound quality compensates for the lack of thereof.
