General Category
General Discussion
Why? input resistor
Why? input resistor
najo49
2235
najo49
Full Member
Why? input resistor
August 12, 2013, 05:06:46 AM
In my 45 amp direct coupled,C4s, with MQ iron. What is the resistor for, the 326 ohm that is in line with the input for.. Not the screen resistor but the inline one. Thanks Jan Olsen
Jann Olsen,
[email protected]
. Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, / 45 amp direct coupled,c4s,mQ nickel / paramour 2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Grainger49
Hero Member
Re: Why? input resistor
Reply #1 on:
August 12, 2013, 10:57:02 AM
Jan,
Do you mean from the hot lead to ground? If so, that is the load across which the source develops its voltage. An open circuit isn't friendly to sources here.
2wo
Hero Member
Test
Reply #2 on:
August 12, 2013, 11:17:23 AM
That sounds like a level matching resistor. If you wanted a bit more gain or just want to you could jumper that out...John
Doc B.
Administrator
Hero Member
Reply #3 on:
August 12, 2013, 11:40:59 AM
Screen resistor? Not likely since the tubes don't have screens. That is probably a grid stopper resistor. It keeps RFI out of the tube's grid.
2wo
Hero Member
Test
Reply #4 on:
August 12, 2013, 06:46:47 PM
I misread the value (326 ohm), as Doc said it is a grid stopper and I would leave it...John
General Category
General Discussion
Why? input resistor
