Bottlehead Kits
Crack
Hot tubes
Hot tubes
Zashoomin
3064
Zashoomin
Jr. Member
Hot tubes
August 14, 2013, 05:14:39 PM
Using stock tubes I was wondering how hot the tubes tend to get.
Paul Birkeland
Global Moderator
Hero Member
Re: Hot tubes
Reply #1 on:
August 14, 2013, 05:31:29 PM
Uncomfortably hot, especially the 6080.
Zashoomin
Jr. Member
Re: Hot tubes
Reply #2 on:
August 14, 2013, 05:52:35 PM
Thank you. Ya all the voltages are correct just checking to make sure tubes are functioning properly. I can't keep my hand on it for more than one second without it becoming a bit painful
Doc B.
Administrator
Hero Member
Re: Hot tubes
Reply #3 on:
August 14, 2013, 06:09:53 PM
We never intended for the user to use the amp with their hand on the tube. I would suggest not doing that.
adamct
Sr. Member
Maxxximum CAPacity Crack
Re: Hot tubes
Reply #4 on:
August 14, 2013, 06:11:37 PM
Mine got hot enough that I eventually decided I shouldn't sit on it anymore. Took me three extended listening sessions to figure that out, however...
Zashoomin
Jr. Member
Re: Hot tubes
Reply #5 on:
August 14, 2013, 07:31:03 PM
thanks its also normal for the aluminum plate to act as a heat sink as well right?
Paul Birkeland
Global Moderator
Hero Member
Re: Hot tubes
Reply #6 on:
August 14, 2013, 07:58:27 PM
The tubes, the power transformer, and some of the resistors in the Crack are warm when they operate. The tubes, power transformer, and some of the resistors in the Crack are also touching and/or close to the aluminum plate, so yes, it gets warm.
Bottlehead Kits
Crack
Hot tubes
