Resistance problem eros phono
najo49 · 3105
Offline najo49
on: August 21, 2013, 06:02:19 AM
I need to check with the forum on some of the resistance reading I am getting. at term 6 I am getting 00 so I checked the connections and found the 470k resistor was not soldered I got things right and when I checked again I still got 00 .IF I lift the 470k resistor at the terminal 6 I get 470k but if I resolder it I get 00.
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
