Help,blew the 10uf tantalum
najo49 · 4333
Offline najo49
on: August 22, 2013, 06:11:16 AM
I got Thur the resistance check ,when I  put power to the eros I blew the 10uf tantalum. I ordered more but I am fear that this was a bad thing to do. What could this involve? And what could have gone down with tantalums?
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Reply #1 on: August 22, 2013, 12:31:34 PM
double check that  you have the polarity correct,  tantalum's do not respond well to reveres voltage...John
Reply #2 on: August 22, 2013, 01:21:41 PM
The tantalums are there to prevent instability and oscillation in the regulator chip. It's unlikely that you have damaged anything else, and if you did it should be easy to figure out what and replace it - there's nothing expensive in that circuit.
Offline najo49
Reply #3 on: August 22, 2013, 02:48:56 PM
Thanks Jon,and Paul. I really hoped I would escape without this kind of bone headed mistake. Eileen sent me out some today,so it sounds like it this is not the end of the world. Jann O.
Offline earwaxxer
Reply #4 on: August 22, 2013, 05:30:20 PM
Jaan - just a suggestion... Next time, embellish a bit more... you know, how it singed off your eye brows. Made you see god... That generates a lot more interest from the peanut gallery... Just a thought.
Eric
Reply #5 on: August 22, 2013, 06:14:14 PM
I don't know, every time I embellish...OK, Lie.
All it gets me, is scorn and harassment ;)...John
Offline najo49
Reply #6 on: August 23, 2013, 06:14:29 AM
I will mention that the two Tantalums are now imbeded in my ceiling above my work area.Still red hot.
Offline pvannest
Reply #7 on: August 23, 2013, 06:18:47 AM
Now that would be a sight...  Hanging tantalums.
Project RPM 1.3, Speed box, Acrylic Platter, Sound Smith upgraded Sumiko EVOIII  Eros, Beepre, Emotive XPA-2, Cambridge Azur 640C, Magneplanar 3.7i's, Dayton Audio Sub.
Reply #8 on: August 23, 2013, 11:50:54 AM
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FSmiles%2FWorthless.gif&hash=9d8ef4862e40664ab4eb2d68fd061c40652dbcd2)
Offline najo49
Reply #9 on: August 25, 2013, 10:35:00 AM
Paul, Can I go ahead with voltage checks w/o the tantalum caps in place?
Reply #10 on: August 25, 2013, 04:39:35 PM
I would not.
