Noise issue / tube replacements?
Tom228 · 4929
Offline Tom228
on: August 26, 2013, 03:57:31 PM
Hi all!
I've gotten a good, solid 50 or so hours on the Eros.  Let me say, I love the noise it makes!  Things sound fantastic.  Though, I have a couple of questions.
First, when the record player is off, and I have the volume up much at all, it sounds like a fan is blowing.  At low volume levels I hear nothing.  But say I'd been cranking some AC/DC and I go to swap the record, I can hear said fan blowing noise.  Is this normal?
Also, the big Hamfest is coming up this weekend.  I know there's a huge thread here on tube replacements.  But it is kinda hard to parse it.  What tubes could I be on the look out for that would be drop-in replacements?  Would I only replace the x79 tubes?  All of them?  None of them?
Reply #1 on: August 27, 2013, 12:18:01 PM
I have a thread of the equivalent drop in tube numbers.  It doesn't say which sounds better or which manufacturer is best.  It will give you the numbers for drop in replacements.  Search for "Eros Tube Equivalents."
« Last Edit: May 04, 2014, 01:43:39 PM by Grainger49 »
Offline johnsonad
Reply #2 on: August 27, 2013, 01:03:43 PM
If at ham fest, keep an eye out for telefunken EF86's/ EF806S and old Amperex bugle boy 6dj8/6922/7308. They shouldn't be too hard to come by and were common in the old tek scopes (at least the 6dj8's were). I use this combo or something close to it in my Eros and Tube Phono and am quite happy with it.
You will have some tube rush at high volumes but it should be quiet at listening volumes.
Offline Tom228
Reply #3 on: August 27, 2013, 02:33:59 PM
Thanks guys.
JohnsonAD - Which tubes go where?
Offline johnsonad
Reply #4 on: August 27, 2013, 04:14:40 PM
Ef86 on the outside tubes (replaces the EH's that that came with it) and a 6dj8/6922/7308 in the middle.
Offline Tom228
Reply #5 on: August 28, 2013, 11:56:16 AM
Thanks!  What would be good prices on these tubes?
Offline johnsonad
Reply #6 on: August 28, 2013, 02:39:03 PM
It's HAM fest! It could be pennies or hundreds! It takes a keen eye and not coming off as an audio only guy to score. You need to know what you are looking for but I've scored some great tubes from the HAM community.
Offline Tom228
Reply #7 on: August 29, 2013, 03:48:41 AM
Understood.  (My first hamfest was in 1990, I go yearly and am an Extra class license holder :*) ).  What I'm asking is - what is a reasonable price range to pay for the tubes you listed?  I have no clue what those prices should be since I've not had a lot of time to research the subject.  Is $20 too much?  $100?  Where does the ripoff line start?
