Bottlehead Kits
Crack
Crack build question
crgolfer
2111
crgolfer
Jr. Member
September 05, 2013, 04:18:12 AM
When doing the final voltage test on the headphone TRS jack my voltage does not drop all the way to zero. It drops to about .02 to .04 volts. Is necessary to get a zero reading or is this ok? All the other resistance and voltage readings check out.
audiophileboss
Guest
Re: Crack build question
Reply #1 on:
September 05, 2013, 05:20:22 AM
Thats fine. No need to woory. Best test is to plug in some headphones and play some music. If it works your fine
Bottlehead Kits
Crack
