Killer front end...
earwaxxer · 5336
Offline earwaxxer
on: September 07, 2013, 04:39:35 PM
Alright, ... I'm semi coherent... Just a disclaimer... but still. I'm REAL impressed with this battery front end, a la Quickie. .. I tell you. The Q is not, by any means the weakest link. Everything cont to get better with it in the circuit. Anyway... Full digital front end with the Q. All battery. Awesome. The reason for the post. I just got a RCA to RCA adapter for the usb/spdif to to rca dac. Thus getting rid of the cable. All good....
Eric
4krow
Reply #1 on: September 07, 2013, 05:41:40 PM
heres the deal, the more battery run stuff the better.
Offline earwaxxer
Reply #2 on: September 07, 2013, 07:11:05 PM
True Greg... Dollar for dollar, battery is definitely the best bet IMO. It gets a bit limited when you need major amounts of power. For the DAC and pre. IMO, its the way to go. Get a DAC that runs off a wall wart. Build a pack that does the deal. In the interest of disclosure though, the Wrd4snd USB/SPDIF converter sounds SOMEWHAT better with battery, though, not night and day. Same with the FiiO DAC. Not huge, but preferred for sure. Cleaner, IMO. I could live with both...
Eric
4krow
Reply #3 on: September 08, 2013, 10:18:43 AM
 Wasn't it the Boulder amp co. in Colorado that produced a battery powered power amp? Don't know the wattage.
Reply #4 on: September 08, 2013, 11:15:13 AM
Just for yucks, try this.  If you have a balanced battery supply, plus and minus the same voltage, put hand matched 10k, or 5k Ohm resistors, matched to the last digit on your meter, across the two supplies.  This will hold the voltage matched.  Then bypass each resistor with a nice film cap. A 0.1uF will be sufficient.  No need to match the capacitors.
Jumpers here are fine.  Let us know if that makes a difference.
Offline earwaxxer
Reply #5 on: September 08, 2013, 01:03:40 PM
Hey Granger - If you could give some more info about what you are saying that would be interesting. Like, what does the resistor filter, and at what values etc. Paul had recommended putting a cap across the power supply in parallel. I tried that once and didnt notice any change. - thanks - Eric
Eric
Reply #6 on: September 08, 2013, 02:29:39 PM
The resistors lock the voltages, the capacitors will filter any noise.
Do you use a balanced voltage power supply, like +/-9V?
Offline earwaxxer
Reply #7 on: September 08, 2013, 02:33:33 PM
Balanced power is another thing I want to understand.. What would a balanced battery supply look like? - thanks much...
Eric
Reply #8 on: September 08, 2013, 05:37:26 PM
It would look something like this, if I understand correctly. If you were thinking well, there
Reply #9 on: September 08, 2013, 11:54:42 PM
John has it.  It is complementary voltages with a virtual ground between them.
Offline earwaxxer
Reply #10 on: September 09, 2013, 04:01:01 AM
Cool! - thanks John and Granger - I will try that!
Eric
Offline najo49
Reply #11 on: September 26, 2013, 07:48:40 AM
Eric, could you give me the name of the supplier for the DAC and the adaptor. Thanks Jann
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Offline earwaxxer
Reply #12 on: September 26, 2013, 02:40:11 PM
The DAC I got from Parts Express and the adapter from Radio Crap.
Eric
Offline ALL212
Reply #13 on: September 27, 2013, 01:22:53 AM
Grainger - can something similar be done for the wall wart switching power supplies?  And, if so, do we need to consider the size of the resistor/cap in watts?  Those Pass amps I built have 19v, 2amp wall warts - keeps the build simpler and keeps those of us who can tell which end of the soldering iron is hot but not much more from killing ourselves on straight AC.  If Nelson Pass approves you have to approve  ::)  but I like to tinker!
Aaron Luebke
Reply #14 on: September 27, 2013, 01:34:18 AM
Yes, it will work but I would go with a three pin regulator for the Pass amps.  Much better.  What I suggested was cheap for a battery supply.  It isn't really an active regulator.
