Wiring for headphones only
Loquah · 4689
Offline Loquah
  • Accidental Tube Addict
    • Passion For Sound
on: September 08, 2013, 11:42:19 PM
Hi all,
I'm building a SEX kit soon and noticed in the manual that it recommends wiring for 32ohms (from memory) if using exclusively with headphones. Can anyone explain to me what impact this has in terms of output impedance and why the 32ohm wiring is recommended? I.e. is it to maximise power output to high impedance cans?
For context, I have a Crack to drive my 600ohm Beyers so I'm looking at the SEX as a more versatile low impedance amp.
Reply #1 on: September 09, 2013, 05:33:09 AM
Using the 32 Ohm tap provides the most output power for headphones.  This tap works nicely with medium impedance inefficient headphones (think orthodynamic).  If you plan to just use low impedance headphones, I would set the amp and 4 or 8 Ohms and leave it alone, as you won't need the additional power that the 32 Ohm tap provides, and the lower impedance taps will have a bit better signal to noise ration.
Offline Loquah
    • Passion For Sound
Reply #2 on: September 09, 2013, 12:20:10 PM
Perfect. Thankyou!
Offline Loquah
    • Passion For Sound
Reply #3 on: September 27, 2013, 11:24:01 PM
I've just been doing a review over on Head-Fi and noticed on the website that it says the 32ohm setup has a very low noise floor. Does that mean that I'm better off wiring for 32ohm if not using speakers? I wired it originally as 8ohm so I could test speakers with it and it has an obvious hum when there's no audio input signal so I'm wondering if changing to 32ohm might fix this.
Reply #4 on: September 28, 2013, 02:00:56 AM
I'm not familiar with the SEX output transformer.  If it is a standard output transformer I think you can wire the headphones for 32 Ohms and the speaker outputs fed from the 8 Ohm tap.
Offline Loquah
    • Passion For Sound
Reply #5 on: September 28, 2013, 02:03:48 AM
That could be good.
What benefits would be gained wiring the headphones from the 32ohm tap?
Reply #6 on: September 28, 2013, 02:11:39 AM
I don't know if you get a benefit with the 32 Ohm headphone tap.  Only that it seems feasible.
Offline Loquah
    • Passion For Sound
Reply #7 on: September 28, 2013, 02:18:44 AM
OK, thanks Grainger.
Can anyone confirm if A) it's feasible and B) how it's of benefit?
Reply #8 on: September 28, 2013, 06:00:27 AM
Lower impedance tap = lower noise floor.  No need to use 32 ohms unless you can't get enough juice from a lower impedance tap.
Reply #9 on: September 28, 2013, 11:03:32 AM
The lowest noise floor will be present on the 4 Ohm setting.
Offline Loquah
    • Passion For Sound
Reply #10 on: September 28, 2013, 12:04:57 PM
Ok, great. Thanks everyone. I'll leave it as is
Offline Lar
Reply #11 on: September 28, 2013, 04:33:43 PM
Just a quick question, can the SEX be wired up for balanced headphone connection? XLR?
Larry V
Reply #12 on: September 28, 2013, 07:17:17 PM
Yes.  This is most easily done by installing the impedance switch kit, then making a speaker cable to 4-pin XLR cable to interface with the SEX.
Offline Lar
Reply #13 on: September 28, 2013, 07:23:17 PM
Thanks, good to know.
Larry V
