weird noise out of the amp *not from headphone*
Kai · 10912
Offline Kai
on: September 15, 2013, 11:12:10 AM
Hello all,
earlier today I was letting the amp run free with a hd800 to burn in the amp.
Since I wasn't listening to the phones, I noticed a very weird noise coming out of the amp.
It sounds kind of like a clicking sound. It also reminds me the sound when you create an arc between two conductors...scary scary..
Please note the following:
*This sound only comes out of the amp, not through the headphones;
*This sound is not loud at all, in fact if there is any other form of sound source in the room, one would not be able to hear this noise;
*This sound would randomly start and stop, I found one way to trigger this sound is to switch the auttenuators. Immediately after you change the volume, this sound would come out and disappear within half second.
I will try to attach a wav file recorded by a sony D50, in order to hear this sound, one need to turn up the volume of their speaker/phones (might try to use an IEM, as this noise really is hard to hear). In this record, you will hear me switching the auttenuators, and right after the switch the sound will come out.
On the other hand, I found no trouble listening music through this amp at all. I don't know if this is normal, and if I should be worried.. ???
Thanks everyone!
Kai
Reply #1 on: September 15, 2013, 11:21:19 AM
It could very well be a bit of microphonics from the switch clicks returning through the 6C45's.
Offline Kai
Reply #2 on: September 15, 2013, 11:25:00 AM
Would it be normal to have this noise though? This noise would also come out randomly even if the attenuators are untouched.
Kai
Reply #3 on: September 15, 2013, 11:34:52 AM
Well, I can't really hear any noises in your recording, but thermal changes in the tube glass can set this off a bit, as well as physical vibration.
Offline Kai
Reply #4 on: September 15, 2013, 11:39:14 AM
PB, it is very hard to hear this noise. I had to turn my speakers up by a lot in order to hear it. On the other hand, this sound can be heard by using a pair of IEM a lot easier...
Offline TubeTim
Reply #5 on: September 15, 2013, 11:55:50 AM
If it sounds like an arc, I would check in a darkened room to see if you visibly see any arcs are visible.
Statement of obvious, don't reach near the 'hot' chassis with the lights off.
_ .. --
  TiM
