voltages are NOT right help
najo49 · 9248
Reply #15 on: September 17, 2013, 01:03:39 AM
Jann,
The Z5Us are the mustard yellow caps on the center tube socket.  At least I remember them being on the center socket.  Looking you will see what I am talking about.  There are a lot of wires and component leads where they are.
Reply #16 on: September 17, 2013, 05:26:45 AM
Jan,
You're kinda all over the road. Without 6.3 on the heater supply, I wouldn't hook the amp up to your system. 1 1V at kreg tells me that the regulator isn't working.
I have made suggestions and asked questions, when you're ready to answer those, I'll be here to help.
Offline najo49
Reply #17 on: September 17, 2013, 06:31:59 AM
Paul, I have not done anything to the caps that go to ground on the center tube, but I will call eileen this morning and order at set of them there are 3. But please be understand that they were not blown, just the 10uf tantalums in the power supply.I will also order a 1050 at the same time then replace all the above. sound good to you?
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Reply #18 on: September 17, 2013, 07:43:18 AM
A replacement 1085 would be the next step, provided you are still getting a low voltage at the output of the regulator, but through your posts, you have called out that voltage as both being low (~4V) and high (~12V), so without being confident about which of those voltage is correct, is very difficult to properly advise you.
Offline najo49
Reply #19 on: September 17, 2013, 09:38:09 AM
paul,thank you for your reply. After checking things this am,this is how things stand. i swapped the tubes and found the low kreg follows one of the ef 86 tube. put it in the right side and everything measures fine. put it in the left side  is fine.The other tube is bad in both sockets The kreg is 1v which is right on.so I ordered a new tube. The filiment voltage is 5.3 volt at the power supply now. it is only a1volt low so do you think that it is the regulator,any way I ordered a new 1085 regulator.
Reply #20 on: September 17, 2013, 10:12:55 AM
Hello Jan,
OK, knowing that the Kreg was on one of the A/B side boards and not the power supply boards is very helpful (I mentioned this in a prior post?).
5.3V out of the regulator is not enough to get the tubes conducting all the way, when you have 6.3V, then judgements can be made about the functionality of the tubes.
Offline najo49
Reply #21 on: September 18, 2013, 05:27:35 AM
Thanks paul, I appreciate what you say,and I have ordered a regulator. But if I might be so bold you are dead wrong about the tube. The preamp will work and play music with 5.3 filiment voltage. So if I sit and try the bad tube in both l and r sockets and neither Produces sound. And them try both left and right sockets and they both play music and supberb music at that. I think that is pretty clear as to what is going on. Jann
Reply #22 on: September 18, 2013, 05:33:37 AM
Jan - the specified voltage for the heaters in this preamp is 6.3V +/- 5%.  (5.99V-6.62V)
5.3V will cause operational problems, and very likely ruin all of the tubes in your Eros (Google "cathode poisoning") with relatively quick speed.
Please do not use the preamp until you can get the 6.3V supply to operate properly.
« Last Edit: September 18, 2013, 05:39:48 AM by Caucasian Blackplate »
Reply #23 on: September 18, 2013, 05:37:22 AM
Jann,
Trust in Paul.  The problem is that without enough heater voltage, and therefore heat, the tube will not pass current as it should.
An extreme example, I have put a 12.6V tube in a socket that needed a 6.3V tube.  I got sound but it was way, way off from the designed sound.  It was all I had on hand.  When I put in the right tube it was amazing what differences it made.
Offline najo49
Reply #24 on: September 18, 2013, 07:16:19 AM
Thanks Grainger for your input,but I understand fully what paul is saying and in theory I completely agree with him. But when I checked this am the filiment voltage was up to 5.7 volt,the regulator obviously can not decide on a filiment voltage, I am not worried about stripping or damage to any tube.Paul is with the paul Joppa, the final word in experience and total understanding of just about anything thats in this forum,they are giants. I am learning but Paul is light years ahead any of my thinking. I am saying only that the tube is BAD. And on that one thing,Paul is wrong. Thanks Paul and Grainger.  PS if I am wrong I will accept it,but until that time I would not bet on it
Reply #25 on: September 18, 2013, 07:28:37 AM
Jann,
Unless your input voltage is wandering all over the place (outside the regulation voltages) the three pin regulator (LM1085IT) should hold the output voltage at 6.3V DC.  That is, if the 124 Ohm and 499 Ohm resistors and the 16V Tantalum capacitor are good.  Maybe you should measure the resistances of the two resistors in the circuit.  As for the Tantalum cap, it either works or doesn't.  But the voltage is set by the two resistors in conjunction with the regulator.
With low voltage I wouldn't worry about damage to the tubes, just poor operation.
Offline najo49
Reply #26 on: September 25, 2013, 05:16:13 AM
I got the parts from Eileen, and I plugged my Eros in and it had perfect voltage. My filliment voltage is 6.0 still not 6.3 but within the 5 % plus or minus. I am going to listen tonight, I am excited. Thanks to all ,Eileen, Paul, and Grainger. Thanks jann Olsen. PS  For break in is it wise to let it run for a few days?
Reply #27 on: September 25, 2013, 05:47:00 AM
Jann,
Congratulations! ! !   Sit back and have an "adult beverage."  Feed it some old favorites and expect to be surprised.
I have been at this for several, too many, decades.  The Eros is an eye opener.
