Painting the cabnet
Guest · 1939
audiophileboss
on: September 17, 2013, 02:59:48 PM
So I bought a crack back in july and I got around to painting the cabnet, but it comes out looking bubbly and bumby, not smooth. What can you guys suggest. And just as a disclaimer, my aunt ordered it for me. Any other questions pls pm me for more information.
Offline azrockitman
Reply #1 on: September 17, 2013, 03:54:15 PM
I'm no painting expert but I've had fairly good results over the years by getting more patient. You don't say if you brushed or sprayed.  Both have consequences.  Sanding with increasingly fine sandpaper produces the best results.  Then making sure to get 100% of the dust off prior to priming. Tack cloth works best for that.  Light multiple coats of paint with super fine steel wool sanding in between coats (again using the tack cloth each time befor the next coat).
Painting inside the house, like your garage, keeps blowing dust to a minimum but you have fumes to contend with.  Outside allows less fumes but more lowing dust.
Bubbling, IMO, means too much paint at once, or some bad paint or surface prep, or painting too quickly between coats.
Most of my mistakes have happened by getting a nice light coat of paint applied, and then screwing it up by thinking it could "use just a bit more on this coat..."  Patience grasshopper
Esoteric DV-50, Technics SL1200-M3D, B&K Phono 10 Preamp, Sumiko Blue Point Special Evo III, Bottlehead Stereomour, Orca's
audiophileboss
Reply #2 on: September 18, 2013, 12:26:29 AM
Yeah I am using a paintbrush and not the finest sand paper. Also I put tons on at once. Oh well, next time I buy a bottlhead kit Iknow what I am doing.
Offline STURMJ
Reply #3 on: September 18, 2013, 04:24:31 AM
You can still sand the base down and start over.
