Speedball voltage problem [solved]
menbom · 3260
Offline menbom
on: September 18, 2013, 09:47:47 AM
So, I have built the standard Crack and have been enjoying that for a couple of weeks. Voltages measured fine, worked perfectly, sounded great, the usual.  :)
Next up, the Speedball. Assembled the boards, attached the wiring, mounted and started measuring. Most voltages check out fine, tubes light up, but there are a few anomalies that I'm wrestling with:
1 - 170V instead of the expected 75-80V
B1 - 170V instead of the expected 75-80V
A8 - 15V instead of the expected 1.56V(the diode here does not light up)
This seems to affect only the small "A" board of the Speedball, the voltages from the "B" board(terminal 5 for example comes in at 82V) all check out fine.
At first, the diode at D2 on the A board did not light up, so I replaced the 2N2907 and then it lit up. After that I tried replacing the MJE350 on the A board, but still the same.
Any troubleshooting suggestions?
/Magnus
« Last Edit: September 22, 2013, 07:37:07 AM by Caucasian Blackplate »
Reply #1 on: September 18, 2013, 10:09:32 AM
If you have one good board and one bad one you can compare the voltages into and out of them.  The most often problems with C4S boards are:
1) Reversed LEDs
2) Swapped Transistors
3) Transistors oriented the wrong way
4) A bad solder joint on a transistor
5) A wrong or badly soldered wire lead to or from the amp/circuit board
Give all these a close look, use a magnifying glass.  Report if you find something.
Online Paul Birkeland
Reply #2 on: September 18, 2013, 10:37:39 AM
Is T2/4 about 170V also?
Do both the diodes on the 9 pin socket light up?
I'd pop off the board that feeds T1 and reheat all of the solder joints, as they are the likely culprits.
Offline menbom
Reply #3 on: September 18, 2013, 11:12:07 AM
T2/4 are 176V.
Only one of the diodes on the 9 pin socket light up, the one on A8 is dark.
Measuring a bit on the boards themselves, it seems that the mid pin of the MJE350 is producing the 82V on board B, but 172V on board A. Tried reheat the whole of board A, taking extra care with the MJE350, as that seems to be the one that should be producing the 82V, but still the same 172V coming out to T1 unfortunately.
Reply #4 on: September 18, 2013, 11:22:17 AM
Can you verify that the red wires leaving the "I" and "O" pads are going to the proper terminals? ("I" is fed by either 2 or 4, "O" goes to 1 or 5)
Do both halves of the 12AU7 glow? (A break in the junction of A4/A5 can cause one half to go dim)
If all else fails, you can swap the little green PC boards to see if the issue follows the board.
Offline menbom
Reply #5 on: September 18, 2013, 11:47:03 AM
Thanks for all the help Paul!
Red wires correctly installed, both halves of the 12AU7 glows(double checked A4/A5).
Swapped the boards around and interestingly enough the problem does not follow the board. I.e. Board A connected to T4/5 measures correctly 82/176V and board B connected to T1/2 measures 172/176V, just like board A in that position did. A8 is still dark.
So I guess I need to trace back further to somewhere before the boards?
Offline Mike B
Reply #6 on: September 18, 2013, 12:33:20 PM
The LED on A8 creates the volt and a half bias.  It should be lit.
It's either blown or in backwards.
Reply #7 on: September 18, 2013, 01:41:00 PM
Mike is correct, the LED is loose or broken. (When they blow you'll hear it from across the room!)
Offline menbom
Reply #8 on: September 22, 2013, 01:14:15 AM
Tada! I had turned the LED the wrong way around when replacing it, thanks for your help troubleshooting.
All works fine now, and sounds great.  :)
Now it's time to try this guy: http://www.ludd.ltu.se/~ragge/ecc82.jpg
w0lfd0g
Reply #9 on: September 22, 2013, 04:45:15 AM
Silver plate?  Very nice!
Offline menbom
Reply #10 on: September 22, 2013, 06:11:43 AM
Yep, unfortunately the right channel is a bit noisy. When I first plugged it in, both channels were noisy, but the left one got better after a few minutes. Hopefully the right one will get better after a while.
