Picture of Mainline Progress - What do you think?
TubeTim · 10713
Offline TubeTim
on: September 22, 2013, 11:57:33 AM
Greetings,
Progress has been slow but thought I'd post the kit build so far.  What is opinion of build quality?
(please see image attached)
The solder joints are "known" good; been doing that for 40+ years now.
It's a whole lot of fun to build and I'm taking my time enjoying it.
Sometimes taking 2 or 3 minutes to route a wire properly. :-)
One thing I'd suggest adding to the manual is checking the fine / coarse attenuators with
an Ohm meter.  I did so after completion of that phase of the kit and know they are wired
fine.
Small error in the manual, page 45, 3'rd paragraph says to solder at C socket but one
should NOT.   Building a stereo amp makes life easier since your doing task twice only,
in mirrored.
One thing I find to help is to cut and strip several pieces of wire (4) then continue building.
Seems to go much smoother this was.  I also review the instructions for the sub-section
so I see where it's going.
_ .. --
  TiM
Offline Chris
Reply #1 on: September 22, 2013, 07:28:14 PM
FWIW, I think it looks superb so far...
Reply #2 on: September 23, 2013, 12:20:09 AM
That is nice, neat work.  It looks like you are doing what I did with my Eros build.  I did 15-20 minutes of work a night and made it as tidy as possible.  My Foreplay and Seduction were not as pretty.
Offline debk
Reply #3 on: September 23, 2013, 01:01:13 AM
Nice work, It look Great!
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline HF9
  • Zynsonix.com
    • Zynsonix.com
Reply #4 on: September 23, 2013, 04:24:34 AM
Looks great, keep up the good work Tim! :)
My DIY Audio Electronics Blog: DIYAudioBlog.com
Offline TubeTim
Reply #5 on: September 23, 2013, 05:53:02 PM
Thanks everyone for the encouraging words!    Really appreciate it.
I added some more wires and put the PWB's on their standoffs so the kit looks more complete than it actually is.
It took about 25 minutes to install 7 wires.  Not a particularly fast pace.
Thanks again,
_ .. --
  Tim
Reply #6 on: September 23, 2013, 06:06:06 PM
That sounds like the perfect pace to me!
(You're actually pretty close to completion, based on your pace, I'd say ~2 hours)
Offline HF9
  • Zynsonix.com
    • Zynsonix.com
Reply #7 on: September 24, 2013, 07:17:23 AM
Nothing wrong with taking your time  ;D I always check and double check my builds, much better to be certain that all steps are correct than rush through a build and then have no idea why it's not working.
4krow
Reply #8 on: September 24, 2013, 09:00:40 AM
  If only all the cords behind my system were as neat!
Offline TubeTim
Reply #9 on: September 28, 2013, 06:50:05 PM
The Mainline build is completed.  The amp is super quiet, can't hear any noise.
Touching L/R input channel results in the expected 60 cycle noise in the L/R output channel.
A real stupid question....  Can one interface a low output (2 or 5 mvolt) turntable direct or is a phono preamp required?
Tim
Reply #10 on: September 28, 2013, 07:16:00 PM
A phono preamp is required.
(Good job completing the build!)
Offline TubeTim
Reply #11 on: September 29, 2013, 05:53:22 AM
Hi Paul,
Thanks for the confirm, I was sure one was needed.  I have a Welborne Labs phono pre-amp for this.
With so many cables the system will be a bit of a mess as 4krow eludes to.
The build was very straight-forward.  One just has to pay close attention, read ahead a bit and quit when tired.
Posting some quick shots of the top / bottom of the chassis plate:
Best Regards,
Tim
Offline Chris
Reply #12 on: September 29, 2013, 07:16:46 PM
Wow, what a CLEAN design... beautifully done... I gotta have one...
