Extended Foreplay Kit Resistor Question.
Natural Sound · 6801
Offline Natural Sound
on: September 23, 2013, 01:10:47 PM
Finally getting around to installing my extended foreplay kit. I'm building the C4S boards and the instructions say to install a 237 ohm 1/4 Watt resistor into R1. My kit came with 4 really tiny 237 ohm 1/8 Watt resistors. Will this be OK or should I get the 1/4 Watts?
For clarification, the 237 ohm resistors are the same size used in the whispers and padding resistors. I'm pretty sure those are 1/8 Watt.
Reply #1 on: September 23, 2013, 01:17:32 PM
Yes, the 1/8 Watt resistors are the correct parts.  (7/100 Watt resistors would be sufficient here)
Reply #2 on: September 23, 2013, 01:18:51 PM
Awesome, thanks for the quick reply, Paul.
