BH 5 with bcp 15 choke
najo49 · 24578
Offline najo49
on: October 02, 2013, 06:38:36 AM
I have the bottlehead upgrade iron for the paramour and my question is if I upgrade my OPT what are my options using the BCP15 choke which I am using now. I am thinking of Nickel opts as a upgrade to my amps,using 45 tubes,but i am hoping to use the chokes I have.  Jann Olsen
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Offline galyons
  • Geary Lyons
Reply #1 on: October 02, 2013, 07:09:44 AM
Thought you got a pair of EXO-050's  on AA?  I am running Paramour 45's with EXO-45Ni and BCP-15.  This was a tremendous upgrade.  Everything got better...timbre, imaging, soundstage, frequency extension.  I am going to replace the cathode cap and the PS 47uf caps with oilers, but the additional improvement is likely to be rather subtle!  Hard to imagine the amps getting much better!!
Cheers,
Geary
« Last Edit: October 02, 2013, 01:28:19 PM by galyons »
Reply #2 on: October 02, 2013, 08:06:23 AM
Geary,
Iron trumps caps every day.  But you will almost certainly like the results.
Reply #3 on: October 02, 2013, 01:07:51 PM
BCP-15's and nickle "Iron", work just fine with the 45 ;)
Reply #4 on: October 02, 2013, 02:57:51 PM
I think that is what Paully is running.
Offline Paully
Reply #5 on: October 03, 2013, 04:48:24 AM
Dude, the honest truth is I don't even know what I am running anymore.  Paramounts got a full upgrade from Magnequest.  Transformers and some chokes, the numbers escape me but full nickel on the OPTs and amp is now in 45 mode.  I'm happy.
Offline najo49
Reply #6 on: October 09, 2013, 08:56:58 AM
I am running 2a3s in my paramours. so what I am looking to do is use the bcp 15 and an upgraded opt. What would be my options?
Reply #7 on: October 09, 2013, 09:34:49 AM
The MagneQuest EXO-35 (16 Ohms) or EXO-36 (8 Ohms) are both good 2A3 output transformers.  Both are available for $180 in all nickel.  (if you are looking for the best, smoothest sound)
Reply #8 on: October 09, 2013, 06:46:39 PM
You say you have the upgrade BH iron. what OP do you have?...John
Offline debk
Reply #9 on: October 09, 2013, 11:10:19 PM
That is the combo I using in my SR45 Amps, it works great
Deb
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
