Quickie chassis
aragorn723 · 8473
Offline aragorn723
on: October 03, 2013, 01:32:05 PM
Has anyone built a Quickie in their own  metal chassis instead of the wood frame ?  Could you share some pictures?  I'm trying to get some ideas for how to layout the inside of a Quickie (i.e. how to mount the tube sockets, minimize wire lengths to rca sockets, etc).  Thanks!
Offline corndog71
Reply #1 on: October 04, 2013, 05:00:24 AM
I kinda went overboard with mine.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_7290_zps13332e32.jpg&hash=9675a965ce14c1188b8e4eb22a49b15950b2e85f)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_6781_zpsea11e3b9.jpg&hash=ee9559a73dae99b92fc83ee60c0b9eb8030be700)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_7281_zps85c83806.jpg&hash=779b44f416fa64e3f869e8de8ceaedba43186eda)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_7280_zps580d60b5.jpg&hash=b0a61871e895857e89cbefcf43a492c0873406e9)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_7282_zps8c2363ef.jpg&hash=3e37849618f577eac0aab5f16521c49f75640919)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_7286_zpseadb64ea.jpg&hash=0e3e557f130ebcd80acf349ecaf289294f564167)
I also built a simple 1 input, 1 output Quickie in a metal file card box with some spare parts.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_7501_zpsb1c1bed3.jpg&hash=e34c3acce057a2a36b3a95ecf421bb1593056021)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_7438_zps8dc5158d.jpg&hash=3cc7e1968e0664ed35ee29547b813108c8a3b4d6)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_2615_zps2e02dd1a.jpg&hash=15a855803a29f28126b919160c3ce6838cf6f334)
Rob
Offline aragorn723
Reply #2 on: October 04, 2013, 11:35:04 AM
That's really cool!  I take it the ultimate battery box is set up so you can disconnect the connectors at the back and charge each battery individually (without opening the box!).  What type of connector do you use for the power connection to the quickie?
Offline corndog71
Reply #3 on: October 04, 2013, 11:54:09 AM
That is correct.  Coincidentally, I just charged each of them over the last couple days for the second time since I got them about 2 years ago.  I was hearing a buzzing sound last weekend and checked the voltages and found them to be down to 15V!  I think I spent $60 on the batteries and another $50 on the CTEK 12V smart charger.  Totally worth it!
Oh and that's a Neutrik Speakon connector.
« Last Edit: October 04, 2013, 11:56:33 AM by corndog71 »
Rob
Offline aragorn723
Reply #4 on: October 06, 2013, 06:55:53 AM
How long do the D batteries last with 2 in series?
Reply #5 on: October 06, 2013, 06:59:57 AM
2 in series will let you run the 3S4 with 3V on the filament, which cuts the current demand in half, so the battery life will double.
Offline corndog71
Reply #6 on: October 06, 2013, 04:41:14 PM
Hold the phone!  Has this been discussed before?  I must've missed it.  2 D batteries in series will last longer?  Does this call for any other changes?  PJCCS?  I should've known - 3S4
It might be time to rewire my ultimate quickie!
« Last Edit: October 06, 2013, 04:43:21 PM by corndog71 »
Rob
Reply #7 on: October 06, 2013, 07:24:36 PM
This isn't that earth shattering.  If you wire the batteries in parallel, you will also get roughly double the battery life.
Yes, you need to make other changes.  The stock circuit wires the filaments in parallel for 1.5V heating, so the paralleled connection needs to be broken.
Offline aragorn723
Reply #8 on: October 07, 2013, 04:44:56 PM
How do you mount the volume pot and selector switch?  Is there a bracket that goes to the chassis?
Offline STURMJ
Reply #9 on: October 07, 2013, 08:17:14 PM
Offline corndog71
Reply #10 on: October 08, 2013, 04:47:53 AM
I used some small brass plates from my local ACE hardware store.  I bent them and cut to size.  I think they were originally 1" by 6".
Rob
4krow
Reply #11 on: October 08, 2013, 12:46:08 PM
  Rob,
    I tend to do the same thing with brass. It is easy to work with, and when used in a way that shows, it looks good too.
   About the battery change up,  if I were to use D cells in this manner, along with the 9v batteries, that would be the time to consider a separate power chassis. Having said that, it would lend itself to even more chassis configurations for the Quickie. Even though simple, I don't like having to take the batteries/cells out from among the circuit. A separate chassis would solve that problem. Off to the drawing board...
Offline aragorn723
Reply #12 on: October 08, 2013, 02:13:09 PM
How do you cut brass?  One of my big concerns is figuring out how to drill the chassis (probably aluminum) and make clean cuts with no burrs/messy holes.  Any suggestions?
Offline corndog71
Reply #13 on: October 08, 2013, 05:38:29 PM
I used sheet metal scissors.  I think they're called something else.
As for drilling holes,  get a good drill and set of bits as well as stepped bits.  Use slower speeds for aluminum.  I use a bigger bit in hand for deburing.  Practice makes perfect.  For larger holes you may want to look at hole punches.
« Last Edit: October 08, 2013, 05:40:25 PM by corndog71 »
Rob
4krow
Reply #14 on: October 08, 2013, 05:51:03 PM
  Rob,
    I don't know what stepped bits you use, but mine have a chamfer built in to de-burr the holes. I use Irwin bits when I can afford them.
    One question that I have about the hole punches. Do they distort the metal when used?
