Wire Sources
Evan · 9164
Offline Evan
on: October 03, 2013, 07:21:39 PM
I've been trying to do a lot of google searches but just can't seem to come up with what I want. So my question to the forum is, where do you guys get your wire?
Particularly I am looking for 22 or 24 awg dual conductor, solid core, shielded wire (like the source wire in the Stereomour kit). And also 20 awg solid core hookup wire. I've found numerous sources for these products with stranded wire, but I'm really struggling to track down solid core. I know plenum CAT 5 from home improvement stores is a good source for solid core 24 awg, but I'd like something a little heavier for higher current loads in different projects.
Thanks for the help with this noob question!
Stereomour => SEOS Fusion 12 Tempest
Crack => Senn HD600
Offline Zimmer64
    • Blog
Reply #1 on: October 03, 2013, 11:08:52 PM
Hi there,
I get most of my exotic stuff from here: http://www.hificollective.co.uk/
Depending on where you live this might not be the most efficient source though.
Kind regards
Michael
Offline kgoss
Reply #2 on: October 04, 2013, 02:14:19 AM
For high quality solid core wire I like www.homegrownaudio.com
Ken Goss
Offline johnsonad
Reply #3 on: October 04, 2013, 03:02:38 AM
Belden 8450
Offline matthewmckay
Reply #4 on: October 04, 2013, 04:18:28 AM
this is another site to check out
http://www.vhaudio.com/wire.html
Offline Evan
Reply #5 on: October 04, 2013, 04:38:10 AM
Awesome! Thanks for the suggestions guys, it helps me break out of the PE and MCM box.
Belden 8450
Thanks Aaron! I was looking through a Belden product PDF and they only listed the stranded part number, it was getting frustrating.
Thanks again everyone.
« Last Edit: October 04, 2013, 04:44:08 AM by Evan »
Crack => Senn HD600
Reply #6 on: October 04, 2013, 04:38:28 AM
If you can afford it, getting something with teflon insulation.  The teflon won't melt off the wire when you're soldering, which is very helpful.
Solid core shielded plenum Cat5 is great for wiring inputs!
Offline corndog71
Reply #7 on: October 04, 2013, 04:49:39 AM
I've been using homegrownaudio wire for over 10 years.  Both the copper and silver wires are easy to strip and manipulate and sound great.  The price of silver has skyrocketed over the last several years so it's not as cheap as it used to be but at least the copper is still reasonably priced.
Rob
Offline WK3K
  • Beginning to see the light...
Reply #8 on: February 27, 2014, 11:54:09 AM
I know this is probably a little late for the OP, but I found this site http://apexjr.com/ to have a bunch of options at reasonable prices. Apparently a lot of his stuff is old mil spec, and I couldn't find a better price anywhere.
Hope that helps.
Witold
Rega P3-24 w/ Rega Exact > Eros II> Quickie w/PJCCS > Stereomour II w/ DC filament supply > Blumenstein Orca Mini/Max 2.1
MacBook > Grace SDAC > Crack w/ Speedball > Sennheiser HD6XX
Reply #9 on: February 27, 2014, 05:50:51 PM
mouser > wire & cables > hookup wire > stranding=solid
gives 675 products, 425 in stock. There should be something there.
Digikey, Allied, etc have similar resources.
Reply #10 on: February 28, 2014, 03:23:45 AM
Some of the wire "navships" sells on ebay is great stuff, i can recommend the 2-3core wire with the white teflon outer layer.  I've used a lot of it for internal interconnects. I believe that stuff was intended for use in aviation, hence the paper tab inside with the spec number.  He also sells a bunch of solid core wire if that is what you prefer.
I tried using cat5 wire in the past but i found it very brittle unless you used the stranded stuff.
http://www.ebay.co.uk/itm/10-feet-24-AWG-Shielded-Silver-Teflon-Wire-3-Twisted-19-strands-cable-/380770809219?pt=US_Audio_Cables_Adapters&hash=item58a7b57583
Offline glennn111
Reply #11 on: February 28, 2014, 12:42:41 PM
I don't post here very often. But I have to tell you that navship on ebay has been my sole supplier of wire for years. I have found the quality to be excellent, and prices to be very reasonable.  Just my 2 cents.
Glenn Sales
Foreplay III (6SN7GTB), last run Paramour I (45 and 76 tubes)
Offline Oberst Oswald
Reply #12 on: March 07, 2014, 04:39:22 AM
I also use Navships.
X-Fi > Stello DA100 > BeePre > SEX 2.1, Beta 22 or Bijou.    Paramounts > Extended Foreplay III > Thiel CS2
Stax SR-Lambda with SRD-7/SB
Denon D-7000
Audez'e LCD-2r2
Sennheiser HD 800
