Voltage readings from headphone jack?
AZvato · 2298
Offline AZvato
on: October 06, 2013, 03:32:11 PM
Hello, noob here. I just finished building the Crack headphone amp and built and installed the Speedball upgrade. Prior to the speedball upgrade my voltage reading from the phone jack spiked at about 12v and quickly dropped down to 0v. I know the manual says it shouldn't go much past 9v but now with the speedball upgrade the voltage now spikes up to 27v but, again, quickly drops down to 0v. All other voltage readings are within acceptable levels. Should the higher reading I'm now getting be a concern since it does return to 0v almost immediately ? I have not yet plugged in a pair of cans and would like some feedback/causes before I do. If it's a problem where should I start on finding the cause of the higher reading?
Offline STURMJ
Reply #1 on: October 06, 2013, 05:19:45 PM
If your other voltages are good then you may want to do this mod,
http://www.bottlehead.com/smf/index.php/topic,2946.0.html
if you haven't already.
Offline AZvato
Reply #2 on: October 06, 2013, 05:40:07 PM
Thanks. I saw that sticky after I posted and wondered if that mod would solve my issue. I think I will try that.
