PJCCS building doubts
charger · 5111
Offline charger
on: October 07, 2013, 02:05:08 AM
Hello,
I am waiting for the PJCCS kit to arrive , I read some posts here talking about mistakes on the PJCCS manual, so what kind of shrewdness should i look to build it? I have just to follow the manual or should I look to some errors on it ?
thank you
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
Offline Zimmer64
    • Blog
Reply #1 on: October 07, 2013, 02:28:29 AM
I do not recall any issues, when I built my PJCCS according to the instructions. Maybe someone else knows more.
Best Michael
Offline charger
Reply #2 on: October 07, 2013, 03:16:43 AM
did you hear any difference with PJCCS mounted on Q ?
Offline Zimmer64
    • Blog
Reply #3 on: October 07, 2013, 03:38:59 AM
Sorry, can't say. I put it in straight away.
Offline Wanderer
Reply #4 on: October 07, 2013, 04:27:31 AM
I ran stock Quickie, choke mods and then replaced the chokes with PJCCS.
Adding chokes increased the gain.  Replacing the chokes with PJCCS kept the gain and made the unit sound (to me) more extended high and low and more dynamic.
There has been some mention that the stock and choke mod Quickie sounds more "tubish" and "Lush" and the PJCCS sounds "drier" and "more accurate".
To me the PJCCS sounds all around better and I have no desire to return to chokes or un-modded. Your taste and milage may vary.
Kevin R-M
Reply #5 on: October 07, 2013, 04:46:29 AM
The first and fifth posts in the Quickie folder are about manual corrections and a change in the look of transistors, respectively.
As a mistake is found the CD-R gets updated and there is a sticky post in the appropriate folder.
Read those two posts, follow the directions and you should have a perfectly operating PJCCS.
Offline charger
Reply #6 on: October 07, 2013, 06:16:28 AM
ok thank you all
Offline charger
Reply #7 on: October 16, 2013, 01:20:23 AM
I just finished assembly PJCCS kit and connected to the Q , it makes really a big emprovement !!
Offline Wanderer
Reply #8 on: October 16, 2013, 03:00:19 PM
Yep, that's what I think. For the price of a couple decent beers and a burger (and a fair tip for the server), worth trying it out.
« Last Edit: October 16, 2013, 03:04:20 PM by Wanderer »
Kevin R-M
Offline charger
Reply #9 on: October 17, 2013, 02:37:52 AM
great difference i saw with Mundorf Supreme too
