Bottlehead Kits
Mainline
E80CC in Mainline
E80CC in Mainline
Loquah
5047
Loquah
Sr. Member
Accidental Tube Addict
E80CC in Mainline
October 07, 2013, 03:59:09 PM
Hi all,
I accidentally placed a bid on some E80CCs, thinking they were the 12AU7 direct equivalent (actually ECC82). Would the E80CC work in the mainline or best to stick with 12AU7? Only asking because I'm going to have some so might as well try them if I can.
Check out my reviews on YouTube -
https://youtube.com/c/passionforsound
Paul Birkeland
Global Moderator
Hero Member
Re: E80CC in Mainline
Reply #1 on:
October 07, 2013, 06:19:53 PM
The regulator is intended to run on 4.5ma at 225V. The cathode voltage at that point should be in the 4-15V range, which it is, so the E80CC will function properly.
It is kind of a waste of an E80CC to use it in a power supply regulator though, IMO.
Loquah
Sr. Member
Reply #2 on:
October 07, 2013, 10:23:45 PM
Thanks PB. As I said, I would ONLY be using it because I accidentally bidded on some.
Maybe I'll try it in my Crack (but I don't want to modify it at all)
Bottlehead Kits
Mainline
E80CC in Mainline
