Parallel coupling capacitors in Crack
Ritchie · 2248
Offline Ritchie
on: October 08, 2013, 04:56:55 PM
Thinking of changing my output coupling caps to film type. Is there any detriment to using multiple caps in parallel to get your required value as long as the values used are the same?
For example two 50uf caps in parallel to get your 100. Non polar of course.
Ritchie
Ritchie M.
crack/speedball as preamp,linn lp12 w/radikal/keel/urika phono, linn majik 4100 active monoblocks,linn majik isobarik speakers(active).
Offline corndog71
Reply #1 on: October 08, 2013, 05:30:37 PM
Go for it.  Make sure the voltage rating is equal or higher as the stock cap.
Rob
